29 November, 2024, 01:58:43 AM *
Author Topic: Handbrake Adjustment  (Read 2862 times)
michaelkaye
« on: 11 October, 2018, 03:10:17 PM »
So I discovered today whilst gently rolling down a slope into a tree that my handbrake on my S2 Sport isn’t great!
I’ve read some threads  about adjustment but what I’m not clear on is whether I need to remove the hub to do this and therefore whether I need this “magic” hub nut removing tool.
Advice gratefully received as ever.
Thanks, Michael.
« Last Edit: 11 October, 2018, 04:16:07 PM by michaelkaye » Logged
« Reply #1 on: 11 October, 2018, 03:58:12 PM »
You should try to rotate the in-hub brass knurled adjusters with a flat blade screw driver through the “hole” in the drum with a good torch you can see what is happening. Rotate the brass nut clockwise to lock the shoes and back off 8 clicks. If that does not work the club has the tool for hire (through me!), but it is out on loan at the mo.
michaelkaye
« Reply #2 on: 13 October, 2018, 06:20:59 PM »
Thank you, all adjusted now. The slack in the cable is gone (and there was a lot of slack) and handbrake working much better.
Re. The hub removal nut tool...good to know, thank you.
M.
