26 November, 2024, 12:27:11 AM *
Pages: [1] 2   Go Down
Author Topic: What is this for  (Read 9868 times)
jimbo64
« on: 18 January, 2019, 08:09:56 PM »
Hi as title not sure what this is for
IanC
« Reply #1 on: 18 January, 2019, 10:45:56 PM »
Well I don’t have one on mine
jimbo64
« Reply #2 on: 18 January, 2019, 11:05:22 PM »
Apparently not many do
« Reply #3 on: 19 January, 2019, 10:37:54 AM »
Is it a bracket for an engine bay light switch?
« Reply #4 on: 19 January, 2019, 10:46:31 AM »
These two pictures seem to have it but not as a light switch mount.
« Reply #5 on: 19 January, 2019, 06:17:14 PM »
Is there a silver component in the same area (second photo)?
« Reply #6 on: 19 January, 2019, 07:33:35 PM »
I think the silver component IS an under bonnet light switch but that it is a on a separate, horizontal mounting tang. I wasn't sure the top picture didn't show a rubber hose going through the vertically orientated fitting.
jimbo64
« Reply #7 on: 19 January, 2019, 08:00:37 PM »
A closer look
« Reply #8 on: 20 January, 2019, 12:15:40 AM »
There is definitely a flick switch in the second photo, that would appear to be nothing to do wth the first photo which seems to be a cable of some sort, there is no sign of this in the 2nd photo at the bracket or under the air box, however there is a cable clamped to the inner wing panel that I suspect is something to do with the switch Huh?
Seems odd though that it's a welded bracket?
« Reply #9 on: 20 January, 2019, 08:13:33 AM »
The hole in it is grommet sized so a cable would be obvious.
« Reply #10 on: 20 January, 2019, 09:28:38 AM »
Does the Fulvia have an under bonnet light?
« Reply #11 on: 20 January, 2019, 10:45:46 AM »
My S2 has a festoon bulb attached to the underside of the bonnet. Not sure about S1's. It seems typically Lancia to produce and weld that bracket just to hold a pipe when they could have used clips on the wheel arch similar to the oil cooler pipes on the opposite side. I haven't seen this bracket before either.
« Reply #12 on: 20 January, 2019, 11:08:15 AM »
Festoon is mounted on middle of bonnet underside on S2 with switch up by bulkhead rain gutter. I think the hole is grommet size so cable with be my thought.
« Reply #13 on: 20 January, 2019, 01:39:26 PM »
How about a mounting bracket for an airhorn trumpet?
https://l7.alamy.com/zooms/e5221b6ee9ce414db9b64c2e11f03971/lancia-fulvia-zagato-sport-1600-engine-hdte8e.jpg
« Reply #14 on: 20 January, 2019, 03:33:27 PM »
S 1 Bulb holder and switch on my 2c are mounted in the centre in front of the drain channel.
8227  Cool
Pages: [1] 2   Go Up
