22 December, 2024, 08:46:31 AM *
Author Topic: No electrical power  (Read 6348 times)
bobhenry999
« on: 23 February, 2019, 04:06:13 PM »
All,
A month or so ago I removed the instrument binnacle from my Coupe as the speedo had stopped working. I have now got a replacement from Italy, and began installing it today.
However, when I connected all the wires and bulb holders etc, and then tested it all, I found that nothing worked. I removed the binnacle, and tried the horn, lights etc, and nothing works !
I put the battery on charge and then put a wire and bulb across the terminals and it lit up fine, but when I put it back in the car - nothing !
The fuses beneath the dashboard are all okay.
Any ideas ?
Thanks,
Bob
Flavia 815 Vignale
Flavia 819 Milleotto
Flavia 815 Coupe Inezione
2000HF x2
2000 Coupe
2000 Sedan x3
Current 815 Coupe Variante 1005
Richard Fridd
« Reply #1 on: 23 February, 2019, 04:44:02 PM »
Earth connected?
bobhenry999
« Reply #2 on: 23 February, 2019, 04:46:20 PM »
Richard,
Which earth are you referring to ?
Bob
Flavia 815 Vignale
2000HF x2
2000 Coupe
2000 Sedan x3
bobhenry999
« Reply #3 on: 24 February, 2019, 11:50:25 AM »
All,
I have just fitted a new battery and still nothing !
Help !!!
Flavia 815 Vignale
2000HF x2
2000 Coupe
2000 Sedan x3
« Reply #4 on: 24 February, 2019, 06:45:42 PM »
All,
Help !!!
Bob have you had a real good look at the battery earth cable, it my be corroded.
8227  Cool
Jaydub
« Reply #5 on: 24 February, 2019, 08:58:27 PM »
Bob
As Brian & Richard said, check the earth lead connection to the chassis is tight and not corroded. Maybe undo it , clean and grease it and refit. Also check the other end of the Live cable where ever  it`s bolted to, starter solenoid or the  starter motor itself. It may have come loose or broken off. Might be worth checking the engine to chassis earth cable as well.
1600 HF. S2.
bobhenry999
« Reply #6 on: 05 March, 2019, 11:19:53 PM »
Chaps,
Sorry for the slow reply, I managed to sort it out after all.
There are three thick red cables and one thick black cable that are attached to the rear of the ammeter by a couple of small nuts, and these have to be connected to provide the electrical power (I guess they must complete some circuit).
Anyway, the upshot is that after a bit of fiddling about connecting up all of the warning lights etc, I now have an instrument panel that all works with fully functioning gauges.
The only exception is the speedometer (The original problem), as the weather has not been nice enough to get the car out, but hopefully I will do so this weekend (Fingers crossed).
Hopefully it will function correctly, and I can look forward to many miles this Spring/Summer.
Thanks for your advice.
Bob
Flavia 815 Vignale
2000HF x2
2000 Coupe
2000 Sedan x3
« Reply #7 on: 06 March, 2019, 07:46:01 AM »
Chaps,
The only exception is the speedometer (The original problem), as the weather has not been nice enough to get the car out, but hopefully I will do so this weekend (Fingers crossed)👍
8227  Cool
Bob
Sounds like a result Bob, fingers crossed for the speedo
« Reply #8 on: 06 March, 2019, 09:03:47 AM »
Test the speedo on axle stands?  What could possibly go wrong...
https://www.youtube.com/watch?v=bqjK6jjt6gk
https://www.youtube.com/watch?v=nmVaIYv8ZLo
« Reply #9 on: 06 March, 2019, 09:28:50 AM »
The speedo is a work of art inside!!! Mine was sooo underreading that I took it out and delved in. A spider had made its home there sometime during the cars long storage. Anyway cleaning carefully and relubing made it work just right. Sorry I did not take any photos.
« Reply #10 on: 06 March, 2019, 11:39:33 PM »
Having all the power going through an ammeter was a thing in the 60s. I had the same on a Vauxhall. A dodgy alternator burned the ammeter out. It was interesting suddenly having no power in the outside lane of a contraflow with no hard shoulder. No engine, no indicators, just a dead car coasting in heavy traffic! I survived.
Page created in 0.035 seconds with 19 queries.
