05 January, 2025, 02:22:19 AM *
Pages: [1] 2 3   Go Down
Author Topic: Appia Camioncino - new arrival  (Read 15218 times)
« on: 08 March, 2019, 06:38:06 PM »
The camioncino has arrived !
The transporter was too big to get through the village so the camioncino was unloaded at the edge of the village and I towed it home with the tractor.
No brakes so you can see me carrying the means of stopping her !
Bit of work to do ........
« Reply #1 on: 08 March, 2019, 06:56:33 PM »
That's a nice addition to the fleet. Looks pretty good in the photos. Is there a lot to do? How are you going to get a 3RO through the village because you know it's only a matter of time....
Cassino
« Reply #2 on: 09 March, 2019, 10:32:35 AM »
She looks in great condition......Have I missed the history of this one?......
Ian
Delta Series 3. Appia Berlina Series 2.
Moto BM Zebretta. Moto Guzzi Leggera 65
Previous Lancias.
 Beta Berlina 1400,Delta 1300, Delta GT,Prisma 1500,Prisma 1600 IE, Dedra 1800, Dedra 2000.IESE.
« Reply #3 on: 09 March, 2019, 08:59:14 PM »
The shiny paint hides a lot ! There is a fair amount to do, but the plan is to do floors , cills , brakes and engine and then see what happens ....
Quite a rare photo opportunity, a camioncino and furgoncino side by side - I had to move the furgoncino out of the garage to put the camioncino on the ramp - Not quite sure where I can put the legs to lift it though !
« Reply #4 on: 17 March, 2019, 02:05:21 PM »
Quick update on this one.
I want to get the car running and at least stopping with the handbrake so I can move it around, so this week I have been trying to start the engine after 22 years of dormancy
The engine was not blocked, had clean oil (!) but no electricity
First job was remove and rebuild the starter motor, diesel down the bores because very low compressions and then a carb clean/rebuild
I by-passed all the electrics, cleaned the points and rest of the ignition and set up jump leads to the starter motor, with a separate lead to the front of the car to engage the solenoid. I also fitted a new petrol pump and new pipes, so no risk of crud from the tank.
Over the course of several days, each time establishing that the next bit worked, I took the heated plugs out of the oven, poured petrol down the carb, fitted a fresh battery and then after about 20 secs of cranking she started ......
I had had a few ignitions before, but she now ran for 30 secs - no more because no water in the engine yet - v good oil pressure and no rattles or nasty noises. Far better than expected !
After that I dismantled all the brakes so that she doesn't bind and can be moved more easily. Next is to check clutch/gearbox and steering etc
« Reply #5 on: 17 March, 2019, 04:34:21 PM »
Brilliant! Bit of a result there Simon.
I have been dealing with dodgy NGK plugs again, this time in our B12.
 This is the 3rd time in the last 5 years that new NGK BP6ES plugs have been found to be faulty. Very frustrating but there are all out of a batch I bought some years ago.
Jaydub
« Reply #6 on: 17 March, 2019, 05:01:03 PM »
Great stuff Simon. I`m with you on the heated spark plugs, it certainly helps to ignite the mixture and partially prevent flooding.
Chris:- I recall NGK  having some issues with bad plugs a few years ago as well, but they are have been ok the last few years as far as I know.
1600 HF. S2.
« Reply #7 on: 17 March, 2019, 06:31:47 PM »
Chris, I think the rest of them need to go in the bin (or put them on eBay !!)
Update on the Appia, filled with water and ran for 20 mins, so getting there slowly
Cassino
« Reply #8 on: 18 March, 2019, 11:20:56 AM »
Well, thats a result.....well done.
Not tempted by a pump with priming lever?......to overcome the drain back issue.
Ian
Previous Lancias.
« Reply #9 on: 30 March, 2019, 10:20:13 AM »
Having started and run the engine, I have now stripped and removed all the brakes so she will move easily, plus i have taken the engine, 'box and prop out so I can start on the welding
Plan is to remove the front wings and doors, then tip it on its side and start the welding. Once I've done the worst bits, I can give her to Dog to make everything look pretty
« Reply #10 on: 07 May, 2019, 05:27:01 PM »
Some progress here
Firstly a couple of scary photos of what I found when I took the doors and wings off - not unexpected and I can deal with most of it with a bit of time and thought.
The "A" posts are pretty shot at their base so I will have to make these carefully and in sections - I can't make complex curves, although I have also acquired a shrinker/stretcher for some sections
The floors and inner cills are very tatty, but floors are available (we made them for the Appia Consortium a couple of years ago) and much of the inner cill is flat metal .I bought a 1m metal folder to help with that
Plan is to replace floors, cills and A posts before turning on its side to tidy up underneath
Using a mix of gas, gasless MIG and inverter depending on the thickness of metal
Maybe do some more tomorrow if the rains arrive !
« Reply #11 on: 07 May, 2019, 11:33:03 PM »
When I saw Simon recently I discovered that folder is about a third the price I expected.  A few on ebay, but for example:
https://www.ebay.co.uk/i/283278025579?_trksid=p11010.c100415.m3733&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D1%26asc%3D20160928092414%26meid%3D8895273c6adf40eb971d6827e7772389%26pid%3D100415%26rk%3D1%26rkt%3D4%26mehot%3Dpp%26b%3D1%26sd%3D273807730304%26itm%3D283278025579&ul_noapp=true
« Reply #12 on: 09 November, 2020, 12:06:45 PM »
After a very lengthy delay - not all CV19 related - The Appia is off to have some much needed metalwork done.
"Dave the Brave" has just arrived from the UK and is working alongside Dog, so he has agreed to do the basic welding before Dog does the paint
Hopefully more photos soon
tzf60
« Reply #13 on: 09 November, 2020, 12:46:53 PM »
Hi Simon  Smiley
Will she be ready to earn her keep in time for next season's harvest??
I see you don't need the tractor to negotiate the village!
Best regards,
Tim F
GerardJPC
« Reply #14 on: 09 November, 2020, 06:11:58 PM »
I love this thread!
1962 Appia Berlina
1973 2000 HF Coupe
1978 Beta 1600 Coupe
1973 Fiat 124 Sport Coupe 1800
1981 Lotus Eclat S2
1982 Moto Guzzi V50 Monza
1982 Yamaha YB 100
1983 Land Rover SIII 88
2005 Alfa Romeo 156 Crosswagon Q4
2009 Jaguar XK 5.0
Pages: [1] 2 3   Go Up
Page created in 0.144 seconds with 20 queries.
