24 December, 2024, 01:07:08 AM *
Author Topic: S2/3 dash into a S1  (Read 2660 times)
« on: 24 April, 2019, 07:34:09 AM »
Hi all
Anyone fitted a S2/3  dash into a S1 car? my car will have a S2 engine and will be able to have a temperature gauge and more legible instruments if a S2 dash could be introduced. It would mean a bit of re-wiring but can anyone see other issues ?
will
« Reply #1 on: 24 April, 2019, 06:35:00 PM »
A problem you may encounter is the second and third series Appias are 60/65 mm wider so a 2/3rd dashboard may not fit in.
The first series instruments just need a good clean if you got the car in bits may be worth sending them off to a specialist to be serviced.
The Appia temperature guage is notoriously inaccurate. If you want a temperature guage may be worth considering  fitting mechanical one with Capilliary pipe which are considered to be very accurate.
Reading the instuments at night can be a problem with an Appia replacing the main battery starter motor lead would help as on my car there was 4 voltage drop on the old cable.
« Reply #2 on: 24 April, 2019, 09:38:00 PM »
Are there any brighter LED bulbs available to help see the instruments?
