22 December, 2024, 06:01:43 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Model Technical and Interest
Fulvia
ARB Cotton reel bushes - NIGHTMARE
Pages: [
1
Go Down
« previous
next »
Author
Topic: ARB Cotton reel bushes - NIGHTMARE (Read 3101 times)
fulvia888
on:
02 August, 2019, 05:25:57 PM »
Hi ,
Am replacing my rather worn ARB rear bushes , have come to the cotton reel bushes on the top of what i'd call the drop link , and am stumped , I just can't seem to get them in , just wondering if there is technique , trick , tool , or am I just not using enough brute force , any advise on the matter would be gratefully appeciated . So far I've focus on the standard square on threaded rod / vice methods , however they just seem to get to a point were nothing has happened except the bush deforms , just cant the lip to go into the drop link , and i give up before I feel it is going to tear the lip off .
Guidance much appreciated - Steve
fulvia888
Re: ARB Cotton reel bushes - NIGHTMARE - resolved
Reply #1 on:
03 August, 2019, 05:14:53 PM »
Well - problem resolved , it was the threaded bar technique that was causing the issue - works for metal cased bushes , however seems that the bar down the centre prohibits the rubber bush from deforming enough to slip through drop link . Ended up just pushing it through and in with the vice , changed to silicone spray for lube as well which seemed to help , a few deft pushes with a screwdriver & done . All new ARB bushes throughout and the set up is far tighter, all the slop has gone , plus changed the shocks and first impression is that it's a lot tighter in the rear - just need to do the same for the front .
Steve
Jaydub
Reply #2 on:
04 August, 2019, 09:52:08 AM »
Hi Steve
Everyone will have their own method that works for them. I have found one way that works for me is to use a length of studding as you suggested, with a flat plate/washer each end. grease the inside of the link (preferably rubber grease) tighten the nuts and when the bush distorts slightly put a wide band hose clip around the lip and that will compress it and with more tightening of the nuts it should slide in. You will need a larger diameter tube or socket on the opposite end to allow the bush to exit the eye of the link.
Good Luck
1600 HF. S2.
Michael Tryton
Reply #3 on:
07 August, 2019, 08:12:49 AM »
Any pictures available to help us visualise methods described?
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
