As we all know one thing leads to another!
One thing - an email from Karl told me of his experience with dynamic wheel balancing on his Augusta so that is my next move. I have tried all five good wheels on a front hub and all seemed well balanced in the radial sense and all five had the balance weights by the valve which Iies in the centre of the partial well of the Michelin wheel rim. Odd at first sight as I thought there would be more metal at that point, however I realised that the partial well brings the raised portion nearer to the wheel centre thus upsetting the balance. I also noticed that the factory installed rim weights are mostly near the valve to counteract the asymmetry.
Another thing - I began to wonder why the Augusta seems more prone to out of balance wheel vibration at the back rather than the front as I have found on all the other cars I have owned. Perhaps a combined effect of rather large fat and heavy tyres on wide wheels mounted on a relatively light axle on a lightish car. I’d already done the spring mountings, shackles etc, cleaned, greased and wrapped the springs which has perhaps modified the innate damping of leaf springs but this cannot be responsible as the vibration was unchanged afterward.
So the only issue left was the condition of the friction shock absorbers which are similar to Andre Hartfords (Photo 142). They have a single moving arm made up of three leaves which join to discs sandwiching 6 wooden friction discs mounted on a chassis bracket, all clamped together by a bolt and spring which pre-sets the tension, unlike the Andre Hartford type where the clamping effect can be adjusted to suit the weight of car and for wear in the friction discs. A fabricated link connects the arm to the axle via Metalastic bushes.
It seemed unduly hard to move the arm of the shockabsorbers by hand, needing a force of about 48lbs/ft to start the lever moving although I have no idea what the correct setting should be. (Does anyone have a figure for this?) Once apart for a clean up, all the wooden discs looked heavily coated with what seemed to have started as grease but was now congealed and hard, looking almost glazed. Wire brushing and paraffin revealed a sound grained wooden surface.
The rubber bushes on the connecting links need replacing and both the surrounds for the upper bush and the links looked very battered, one arm having evidently been broken and welded together with a patch. (Photo 143) One of the connecting links is sound enough and looks original but the other is not very good. So more fettling awaits!
Making a replacement connecting link will be tricky so if anyone has a sound original link they can spare I’d be glad to buy it. (Photo 144)
When it comes to re-fitting them to the car I will test the action of the friction by a simple technique I’ve used before with Hartfords. Jack the car up, supporting it beneath the chassis, jack the axle up and then set the tension of the clamping bolt on the discs so that the axle will only just drop as the supporting jack is lowered. This seems to work well for Hartfords and will give a guide as to whether the Augusta’s shocker setting is in the right zone, but what to do if it is not - I’ll wait and see.
Mike
