Another day of tweaking propshaft issues yesterday!
I checked the gearbox output shaft and the pinion shaft spigots on the which the centering spiders of the propshaft run - they both run true.
I tested the balance of the Hardy discs by fitting centering spiders to both sides of a disc and then rolling it on the knife edges. I must congratulate the supplier of the discs which were not only dimensionally very correct but very close to being perfectly balanced so no problem there. The discs weigh 490gms and needed no more than 2-3 gms added to one of the bolts to make them roll evenly. To give you an idea how small this is, an 8mm washer weighs about 2 gms.
I retested the propshaft with the discs fitted but they still were a little bit off balance whether they rolled on the bosses of the centering spiders or on the tube itself.
I then turned to the bolts, 10 of which are original with castle nut and split pin and two non original with self-locking nuts (these were mounted opposite to one another so should have been in balance). It turned out that the original bolts weigh 22gms and the castle nut 8 gms, a total of 30gms. The spurious bolts weighed 24 gms and 26 gms apiece including the nut - these are 7.8mm diameter and 1.25 mm pitch rather than the correct precise 8mm and 1mm pitch of the original bolts, the lighter of the two spurious bolts also has a 13mm head rather than 14mm. I added two washers to one of the miscreants and three to the other and put them opposite to one another on the disc. The whole propshaft with discs would now roll pretty uniformly on the knife edges, whether riding on the tube of the shaft or on the bosses of the centering spiders. This also confirms that the centering spiders are in true alignment with the rest of the shaft
I was a little sceptical as to whether such small variation matters, but nevertheless put it back on the car and this morning in brilliant sunshine had a test run. Amazingly even such a small balance correction on the bolts does have an effect as the vibration is now hardly noticeable just around 3100 rpm but then fading away up to my personal 3500 rpm limit. I’ll machine two new bolts to the proper size and weight, starting with a standard 10mm bolt, and leaving the head a bit deep so I can make a final weight adjustment. Too cold in the garage this evening and it's snowing!
I still find it hard to believe such a small weight difference could make a difference, but it evidently does.
This leads me on to a more general question - why is it that Lancias seem so sensitive to a slight imbalance which by all accounts is not confined to Augustas?
