My appologies, I specified the correct spring, but located it incorrectly. The spring that is broken on mine is the top spring. As a stop gap solution, I have leveled of the broken part of the spring and made a spacer to fill the gap. I know that it will be a harder spring, but, better than no spring at all. (I have found some available on Ebay from Italy). Thanks for the replies, by the way. Very helpful and re-assuring. I have finished and re-fitted the 34-5595 cup at the bottom, with soft solder. I have also built up and finished shaped the worn 34-5587 (main "king pin") as described by Morris Parry. I was rather worried about the brazing rod I used, so I have made it .01 undersize and have nickel plated it to bring it up to 35mm in diameter (which I calculated to be the original specification). I made two test plating's using similar size and type material, to get the voltage and current correct. Then tested the resulting finish. I hit the plating with a ball pein and it dented and conformed, without delaminating, I then tried to file it and the file skated over the surface. So I went ahead and plated the original. All looks very promising. I have just moved on to the re-assembly and have been researching the oil to use. I have posted my thoughts on the subject in the "suspension oil" thread on this formum. In summary, I will be using a 32 weight hydraulic oil. (as used in motorbike front suspension)
I will be making new dust caps as suggested. The tools lent to me by Mike have been fabulous and help from the forum equally re-assuring.
