Here is the Augusta clutch. Top centre is the pressure plate (the disc) with the central boss which carries the clutch release bearing. Inside the bearing is the clutch release dog, mounted on a hollow shaft with a nut on the inner end which is pulled back by the action of the clutch pedal and via the thrust bearing pushes the pressure plate back away from the lining to disengage the clutch. The pressure plate unit is fixed to the flywheel by the three spring steel arms which flex to allow the plate to move away from the flywheel.
The spigot shaft, not shown, goes through the hollow centre shaft, is splined to the clutch plate and aligned by the gearbox input shaft between flywheel and box.
Top left is the cover plate, a very thin steel pressing, attached to the flywheel by three bolts, which compresses the spring against the central boss of the pressure plate unit.
The flywheel, most unusually does not fit to a taper on the crankshaft but is held in place and driven by four bolts which screw into the end of the crank - they are strong! I’ve seen that many of the components have a small round indent, showing that they were routinely tested for hardness, and this includes the four bolts.
Today I have made a fixture to prevent the flywheel from rotating while I undo the four flywheel bolts to replace the centre spigot ball race. I work on my own, often for a couple of hours in the evening so I don’t have a handy assistant.
Mike
