22 December, 2024, 06:02:41 PM *
Pages: 1 ... 9 10 11 12 13 [14] 15 16 17 18 19 ... 25   Go Down
Author Topic: Y10 FIRE LX  (Read 127020 times)
Kevinlincs
« Reply #195 on: 09 September, 2020, 10:48:20 PM »
Knew about the grille having rust, seems like it will be an awkward repair, bound to be rusted down the fins..
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #196 on: 12 September, 2020, 09:19:30 PM »
Passenger side rear quarter repairs done now, very happy with the outcome.
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #197 on: 12 September, 2020, 09:21:19 PM »
Started on the drivers side now, rust is worse on the bumper mount reinforcing bracket but rest pretty much the same
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #198 on: 12 September, 2020, 09:22:51 PM »
Bracket had just the bottom half useable which handily is the main piece, top half I'll remake to suit.
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #199 on: 15 September, 2020, 09:01:48 PM »
Work continues, drivers side rear quarter repairs on the menu today.
Not as much of a blind alley now I've done one side.
Corner piece welded in once I'd got down to the solid metal that is.
Then a repair piece for the inner lower panel to join to the reinforcer.
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #200 on: 15 September, 2020, 09:03:53 PM »
The salvaged bottom half of the bumper bracket mount then needed fitting, and the missing upper section making as this side is also the towing bracket so needs to be strong..
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #201 on: 15 September, 2020, 09:07:26 PM »
Not as per OE but strong enough and fit for purpose
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #202 on: 15 September, 2020, 09:08:46 PM »
Just had time to make up the outer skin..
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #203 on: 15 September, 2020, 09:10:22 PM »
Fit is decent again using the rear light as a guide and measurements taken before cutting the old one off..
I'll make up the inner sections tomorrow before the outer can be welded into place..
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #204 on: 16 September, 2020, 07:17:09 PM »
Today I repaired all the inner sections to box the rear inner arch in.
Then the outer skin went on.
Sounds simple but needed to keep making bits and trial fitting but I got there.
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #205 on: 16 September, 2020, 07:18:27 PM »
Trial fitted the bumper and rear lights, happy to say it all lined up nicely.
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #206 on: 16 September, 2020, 07:20:34 PM »
All ship shape at last with no rot left at all. Should be good for a number of years to come.
Next visit I'll start on the windscreen surround, most of which will be fairly straightforward apart from the section at the vents...
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #207 on: 18 September, 2020, 08:12:08 PM »
Drivers side windscreen corner rust repairs now started..
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #208 on: 21 September, 2020, 07:57:24 PM »
Making my way around the windscreen surround now, not as bad as it could be. Just small pieces that need replacing, rest is cleaning up OK.
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #209 on: 21 September, 2020, 08:00:41 PM »
All across the top cleaned up just fine using a knotted wheel for the rough stuff, then a carbide bit to dig into the pitted bits then a hand held grit blaster to clean the remainder up got it back to all good clean metal.
Passenger side had a couple of spots that looked a little thin after the same process so just simpler to cut it out and weld in new metal whilst at this stage.
Flavia 815 coupe
Delta integrale
Pages: 1 ... 9 10 11 12 13 [14] 15 16 17 18 19 ... 25   Go Up
