12 January, 2025, 09:30:14 AM *
Author Topic: prewar bosch generator 'controler' housing  (Read 5946 times)
Dikappa
« on: 05 May, 2020, 07:26:31 PM »
Long shot but I'm looking for the housing like on this generator.  No internals needed as my generater has modern electronics, but in a wrong scintilla housing....
If you have a complete unit or even complete generator, i'll consider anything...
Dilambdaman
« Reply #1 on: 27 May, 2020, 02:03:32 PM »
Hi Koen,
I think I have what you need. It's on a spare generator I have for my Dilambda, I just had to find where I'd stored it!
The generator it's on is 120mm diameter and the box is 90mm x 75mm x 65mm. Terminals are numbered 51 & 61
You say that you don't need the inside mechanism so could I please keep that. I don't use it on mine having converted to a more modern set up but you never know! I'd also obviously like to keep the generator.
I deliberated on whether I should let the box go but the chances of me ever needing it are slim so I'm happy for you to have it.
Is it for the Casaro MM you are building?
Kind regards,
Robin.
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
Dikappa
« Reply #2 on: 27 May, 2020, 05:10:10 PM »
Robin,
Yes it's for the casaro, I have a 9th series dynamo/iginition, but the regulator is a scintilla box, with modern internals.
But in all honesty, this is just a detail, and even it would be nice to have the correct box for the regulator, I think you should leave your dynamo in one piece.
I don't like you to break up a nice original dynamo in pieces....
Dilambdaman
« Reply #3 on: 28 May, 2020, 01:00:28 PM »
Koen,
Thank you for being so considerate.
As I said, I did think long and hard before offering it to you but in the end felt that it was better for it to be on a running car than sitting on my shelf. It would also give me great pleasure to have provided a small contribution to your wonderful recreation.
So, the offer is still there if you don't find another and the Sintilla box irritates you.
Love the restoration blog and very impressed with the high quality of the workmanship. Very much looking forward to seeing the finished restoration.
Robin.
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
Dikappa
« Reply #4 on: 29 May, 2020, 04:40:40 PM »
Ok Robin, thanks very much.  I will keep your kind offer in mind, and if nothing else turns up in the year I'll undoubtedly need to come near a finished car, I'll take you up on in.
But I'd much rather canibalize some mercedes generator than a true Dilambda one.....
Cheers,
Koen
JohnMillham
« Reply #5 on: 29 May, 2020, 06:39:53 PM »
The Lambda dynamo has a distributor attached to it. What are you doing about a distributor?
Dikappa
« Reply #6 on: 29 May, 2020, 09:30:55 PM »
John,
I have for my car a completely rebuilt 9th series bosh dynamo/distributor, only it has a Scintilla regulator attached to it, with a modern regulator inside, but, according to Bill Jamiesons book, the original regulator housing looks like the one in the picture I posted.
The 9th series used coil ignition.  I'll make a pic tomorrow.
Dikappa
« Reply #7 on: 30 May, 2020, 10:20:44 AM »
here's some pictures of the ninth generator/ignition
JohnMillham
« Reply #8 on: 30 May, 2020, 08:04:55 PM »
That's good. Is the rotor arm bent?
Dikappa
« Reply #9 on: 31 May, 2020, 08:03:17 PM »
Just went to check, its just the picture...
Dilambdaman
« Reply #10 on: 31 May, 2020, 11:08:19 PM »
Koen,
Having now seen a picture of the Sintilla generator control box I hope that you are successful in finding one or come back to me for mine!
Robin.
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
JohnMillham
« Reply #11 on: 01 June, 2020, 06:39:51 PM »
Here is what I think you need. Send me your address and it's yours. Regards, John
Dikappa
« Reply #12 on: 11 June, 2020, 04:08:44 PM »
The correct box arrived!  With thanks to John!  It needs a little tlc, pictures when fitted to follow!
The power of the forum!
Page created in 0.168 seconds with 19 queries.
