Engine oil: 4 liters, gearbox oil 2.7 liters (2 drain plugs), top up steering box oil (80W-90 type). Apart from general servicing (brakes, tyres, electrics etc), it is important to add a few drops of engine oil to the small hole in the distributor baseplate (usually marked as "olio"). Fulvia engines are very sensitive to points gap (dwell angle), ignition timing and carb balancing.
As I am today carrying out annual maintenance on my S2 coupe, I found the thread of the gearbox rear drain hole damaged. Not wishing to take the gearbox out (
), I made a tap by using an old drain plug, my Dremer, cutting oil and thread chaser. After repairing the thread, so far there is no leak and I hope it will stay like that. Andrea
