Author Topic: Y10 GTie (LHD)  (Read 59658 times)
Duncan23
  • Lapsed
  • Member
Re: Y10 GTie (LHD)
« Reply #30 on: 25 August, 2020, 08:55:28 AM »
Thanks Mike, I think that's probably the best plan. And it's free as well. :)
I've just been out for a quick blast, and it's so much fun. The pedals are really close together which took a little getting used to, and every time I went over a sharp edged bump the dashboard felt like it was going to fall off, but it just wants you to throw it around corners, and while the steering is heavy at low speed it's great when you are on the move. Would be nice if I could see the speedo (or the rev counter) through the steering wheel, but it's all kph anyway, so it's not a huge amount of use!
Putting the window down gave me quite a strong whiff of petrol - I guess that's got to go above the interior on the list of things to fix. Might just be the exhaust - if I remember properly it was an advisory on the last couple of MOTs. Will have to investigate when I next get half an hour...
If you post up a picture of your dials, I'll look & see whether the instrument binnacle I have could yield you an MPH speedo.
That's an interesting idea. I was planning on just sticking a mobile phone with GPS speedo to the windscreen, but a working speedo would probably be better! Is this  agood enough picture?
2020-08-24_08-15-46 by duncancmartin, on Flickr
Duncan
m tulloch
  • Megaposter
Re: Y10 GTie (LHD)
« Reply #31 on: 26 August, 2020, 09:04:36 AM »
I'll have a look today & send you a picture of what I have.
  • Press Officer
  • Permanent resident
Re: Y10 GTie (LHD)
« Reply #32 on: 26 August, 2020, 09:28:06 AM »
HI I hope you found the cause of petrol wiff. I would check all rubber fuel hoses especially on the underside.
m tulloch
  • Megaposter
Re: Y10 GTie (LHD)
« Reply #33 on: 26 August, 2020, 05:15:37 PM »
Had a good look today but couldn't find the Y10 instruments I used to have, sorry. I did find the dash from one of my old Deltas though! ???
Duncan23
  • Lapsed
  • Member
Re: Y10 GTie (LHD)
« Reply #34 on: 26 August, 2020, 06:02:24 PM »
No problem, thanks for looking.  :)
Duncan23
  • Lapsed
  • Member
Re: Y10 GTie (LHD)
« Reply #35 on: 28 August, 2020, 04:52:04 PM »
That manual turned up this afternoon. That's this weekend's reading sorted. :)
If it ever stops raining I'll put some cardboard underneath it and see if anything drips on it. When I can get it up in the air then I'll give all the hoses a good inspection. I was considering if I should just replace all the rubber hoses - they could probably do with it if they are 30 years old.
Re: Y10 GTie (LHD)
« Reply #36 on: 02 September, 2020, 02:40:22 PM »
The trim panel above the ashtray is where the window switches were mounted on earlier models. The Touring had a row of four switches because the rear side windows opened electrically too.
Duncan23
  • Lapsed
  • Member
Re: Y10 GTie (LHD)
« Reply #37 on: 02 September, 2020, 02:48:50 PM »
OK, sounds like it should just be a blanking plate on mine then.
The manual is a bit strange.  There's a load of useful information in the sections titled "Introduction Technical Data", "Engine", "Electrical Equipment", "Auxiliary Units" and "Bodywork", and absolutely nothing in Clutch, Gearbox Differential, Braking System, Steering, Suspensions and Wheels. There's also an appendix for the selectronic stuff. I guess all the missing information is unchanged from Volume 1.
  • Administrator
  • Rebel Poster
Re: Y10 GTie (LHD)
« Reply #38 on: 02 September, 2020, 05:06:31 PM »
Hi Duncan
Given the horror stories about modern fuel and old rubber pipes, I would change out all the rubber pipes for branded ethanol tolerant (R9?) pipes. There are also stories about unbranded R6 pipes being relabelled, so better to buy branded from reputable supplier, my personal view.
This then leaves the question of what to do about the rubber components internal to the likes of carburettor.
Re: Y10 GTie (LHD)
« Reply #39 on: 02 September, 2020, 06:56:57 PM »
This usually the case with all the Lancia models.
8227  8)
Re: Y10 GTie (LHD)
« Reply #40 on: 03 September, 2020, 10:56:33 AM »
Brakes, steering, suspension etc are covered in the Fiat Panda Haynes Manual which is handy to have because it doesn't tell you to get out a special tool to do something simple.
Duncan23
  • Lapsed
  • Member
Re: Y10 GTie (LHD)
« Reply #41 on: 03 September, 2020, 11:36:35 AM »
That's a good idea. There are a million on eBay, with a bunch of different years - I assume they are all basically equivalent?
  • Press Officer
Re: Y10 GTie (LHD)
« Reply #42 on: 03 September, 2020, 03:06:53 PM »
The club has loads of special tools For hire for Y10!!! But a big hammer and blunt instrument may suffice....
Re: Y10 GTie (LHD)
« Reply #43 on: 03 September, 2020, 07:03:27 PM »
On the Haynes Manual I use the green one that runs up to 1995 because that better matches the Y10. Stuff the Y10 had was passed on to the next generation of Panda so early Pandas are less similar.
Duncan23
  • Lapsed
  • Member
Re: Y10 GTie (LHD)
« Reply #44 on: 05 September, 2020, 03:56:13 PM »
Quick question - what size tyres are people using, on the car and the spare?
The car and the spare have 175 70 R13 on - the manual says it should have 155 70 R13 or 165 65 R13, and the spare should be 135 SR 13, but doesn't give a middle number. I need to change the spare tyre as this one won't fit under the bonnet - is it worth changing the tyres on the car (these ones are clearly too big)? And are there any specific ones to choose/avoid? They are all pleasingly cheap at this size.
