I've been doing little bits and pieces on this, but today I got on with it properly.
So far, this is what I've managed to remove:
2021-01-16_07-20-08 by
duncancmartin, on Flickr
Obviously, various bits of flimsy plastic broke while I was removing things, the most annoying being the vent at the edge of the dash. The manual says "prise it out" and shows a picture of someone levering it out with a screwdriver, but it snapped in half (and a piece came off the front as well). Does anyone know if the RHD and LHD ones are the same unit just turned upside down? Otherwise I'm guessing this might be quite tricky to replace (assuming any spares exist and they haven't all destroyed themselves on removal).
The only thing that is stopping me from removing the dashboard now obviously aside from the one screw I probably didn't know existed and so will rip out some more plastic) is the heater controls. They are loose, but there are 3 cables that go through grommets in the dash and are going to need to be removed from the back of the control unit (the manual backs me up on this one). However, I can't work out how to disconnect them (on this the manual is less helpful). Anyone got any ideas? This is what it looks like behind the heater:
2021-01-16_07-20-29 by
Once the dash is out, then I can look at how I'm going to hold it all together (need to order myself some fibreglass) and also how I recreate mounting points so it all goes back together again properly. Also, while the stereo turned on and changed radio channel, it wasn't making any noise in the car, having pulled it out of the dashboard, I discovered why. All the output leads weren't connected to anything! The install is a right shoddy job, the wires are just soldered up and individually taped, so when the dashboard is back together I'm going to have to restore some semblance of order and connect them all back through a sensible block, but that can wait for now.
