21 December, 2024, 03:09:43 PM *
Author Topic: Aprilia doors opening angles  (Read 4213 times)
John Larkin
« on: 21 August, 2020, 11:18:07 AM »
What should be the total angular movement of the front and rear doors of a 1949 S2 Aprilia berlina from the closed position to fully open?  Mine do not seem to open as wide as some that I have seen while scouring photos on the internet.
Regards,
John Larkin.
John Larkin
1949 Aprilia berlina
« Reply #1 on: 21 August, 2020, 02:03:05 PM »
I will measure mine (47 S2 Berlina), however it may be easier to measure opening distances - my trig skills are a bit rusty , all I remember is SOH, CAH , TOA
Raahauge
« Reply #2 on: 23 August, 2020, 05:22:48 PM »
John.
I have today had to adjust one of our rear doors which was opening too far.
This gave me a chance to have a good look at the construction and it seems inevitable that opening angles will vary.
The stops are welded to the shell in what looks like a slightly random way, (none of mine are vertical). There is no provision for adjustment.
Because the sockets that the door balls sit in are able to rotate and move in and out to accommodate door fit, the point at which the finger will hit the stop will vary.
On none of my four doors do both top and bottom fingers hit both stops.
If the door fits the opening then I think the only adjustment would be welding a bit on (as I have had to do) or filing some off if you need more opening. Hope this helps.
Best wishes.
Dave Gee
« Reply #3 on: 24 August, 2020, 08:24:54 AM »
 John
    Door opening 1938(?)  Aprilia
    Taken outside just above the swage line
       Passenger side rear 138 deg   passenger front 128 deg
       Drivers side rear 126 deg  Drivers door 122 deg
     All doors are approx 2mm clear of the body when fully open.
Hope this is helpful.
     Dave
John Larkin
« Reply #4 on: 26 August, 2020, 04:10:14 PM »
Dear Dave,
Thank you for the measurements from your car.  Am I correctly interpreting the angles you gave in my attached sketch?  I hope the attachment works!
Regards,
John Larkin
John Larkin
John Larkin
« Reply #5 on: 26 August, 2020, 04:13:25 PM »
Hi Raahauge,
Information much appreciated!
Thank you.
Regards,
John Larkin.
John Larkin
Dave Gee
« Reply #6 on: 26 August, 2020, 06:30:00 PM »
  John
  That's correct.
Best wishes
Dave
