25 November, 2024, 10:36:55 AM *
Pages: 1 [2] 3 4 5 6   Go Down
Author Topic: '72 Fulvia rebuild  (Read 32247 times)
Keithver
« Reply #15 on: 15 October, 2020, 12:20:25 PM »
The car is about to go to the bodywork/spray painter to do all of the structural work (sills etc) that I'm not comfortable handling. I am checking the fit of windows etc  before she is painted so that I don't have to do it with new bright shiny paintwork.
Am I right in presuming that the outer door edge that takes the s/s outer trim should be a straight line. (see photo)The two "U" channels that secure the vent window at the front give an opening of 16/17mm. should that continue all the way back to just behind the opening for the lock knob. Are the inner and outer lips parallel? mine were all over the place before I straightened the one in the photo
'72 series 2 Fulvia 1,3s
nthomas1
« Reply #16 on: 16 October, 2020, 10:17:54 PM »
The sides should be parallel.  The width of the front section where the quarter light fits is determined by the three cross braces where the captive  nuts are located.  I can't recall if the rest of the opening is the same width or slightly different.   You can probably judge by looking at the width of the major portion, then ease (usually) narrower areas out to match. The gap has to take the following, reading from the inside of the car outwards:  rear surface of inner door top grained trim piece; furry weatherstrip; glass; furry weatherstrip; inner portion of external stainless steel trim strip.
« Last Edit: 16 October, 2020, 10:20:05 PM by nthomas1 » Logged
Norm Thomas
Ormskirk, Lancashire
Own:
1973 Fulvia S2 Coupe
Keithver
« Reply #17 on: 17 October, 2020, 11:26:25 AM »
thanks Norm. The rear flange for the vent fixing was buckled and caused a large crown (horizontally) along the outer lip. Reshaping the flange back to original has lessened the crown and it now matches the other door's slight crown. I have the inner and outer lips parallel. I only have the old trim bits and pieces at this stage (all to be replaced with new), but they seem to fit properly now. Thanks again for the help. Appreciated
Keith
Keithver
« Reply #18 on: 20 October, 2020, 09:18:10 AM »
I am going to have to make a final choice on the colour of the car soon and rather like the colour in the photo. Can anyone tell me definitely what the name of the colour is please
Lightweight_911
« Reply #19 on: 22 October, 2020, 07:28:05 AM »
That looks like 'Turchese Mereweld' - one of my favourite colours for an S1 Coupe ...
I don't think it was offered on S2 models though.
« Reply #20 on: 22 October, 2020, 07:37:51 AM »
If metallic (hard to tell) then Blue Jamaica (the light version)??
Keithver
« Reply #21 on: 22 October, 2020, 01:36:29 PM »
The website where I got the photo from said the colour is Blu Mendoza. I think this is too light for Mendoza. The other photos of the same car all show the colour as an almost cyan colour. Turchese Mereveld is a good call, but an internet search shows as many light green cars as light blue?Huh?. Paul Mayo (member of the forum) shows it as a green colour in his extensive colour chart. I cant find the cyan colour on his chart though unfortunately.
The colour in the photo above is not metallic. I think my car was originally Blu Jamaica. As in the inner darker ring in the photo. I didn't realize that there was a lighter version of the Jamaica.
I really like the cyan and would like to use it. I'm not building a concourse car. Would it matter if I used a series 1 colour on a series2 car?
Lightweight_911
« Reply #22 on: 22 October, 2020, 02:43:16 PM »
Looking at the S1 Coupe shot above on a different screen/device it now looks much 'bluer' so my suggestion of Turchese Mereweld was obviously incorrect ...
« Reply #23 on: 22 October, 2020, 03:48:19 PM »
Hf Azzurro. Really light blue
Beckerman67
« Reply #24 on: 23 October, 2020, 04:56:08 AM »
 Found this which looks a close match in some of the pictures:
 http://www.mrspeedlux.com/1967-fiat-124-sport-coupe/
Keithver
« Reply #25 on: 23 October, 2020, 07:32:17 AM »
You are right Robert - it does look similar in some of the pics. The Turchess (turquoise in Itallian) seems a little green though. Doing a google search for Azzurro (light blue) returns a whole lot of Fulvias in the right colour.
Is there an official Lancia colour chart anywhere that one can look at?
Thanks for all the suggestions so far
« Last Edit: 23 October, 2020, 07:34:50 AM by Keithver » Logged
Beckerman67
« Reply #26 on: 23 October, 2020, 08:08:30 AM »
 This any help? - Aussie website!
 https://www.uniquecarsandparts.com.au/paint_color_reference_lancia
« Reply #27 on: 23 October, 2020, 08:29:13 AM »
Azzurro HF   MM 1.346.7215   lecher 8073   Only for 1.6HF S1
Keithver
« Reply #28 on: 23 October, 2020, 09:23:59 AM »
Wow Robert Thanks. What and amazing site. It looks like it is Azzurro (HF) .
Thanks Tim. I cant want for more than that. Even if it is only for HF. I'm still very tempted to use it
Thanks all for the help Smiley Smiley Smiley
Keithver
« Reply #29 on: 04 November, 2020, 12:31:23 PM »
I wasn't able to find a comprehensive guide to Fulvia colours. The parts book lists all the names, Lancia numbers and other codes. Nowhere could I find a colour chart with all the colour samples. I googled the different colours and selected paint chips and car colours that seemed right. (when I could find them) I'm not the expert. This is my attempt at making my selection easier and I thought that others might find it helpful. Please let me have comments and suggestions. I'm not sure that this post should be under Fulvia, even though it is about Fulvias, but maybe there is a better place for it. Here is the link
https://www.dropbox.com/home/fulvia%20colours?preview=colours2.pdf
Pages: 1 [2] 3 4 5 6   Go Up
Page created in 0.096 seconds with 20 queries.
