13 January, 2025, 05:03:44 PM *
Author Topic: [SOLVED] - Sticking on badges on your Car  (Read 7494 times)
sparehead3
« on: 09 April, 2008, 11:50:54 AM »
Here's a question : technical but general so I've put it here :
What would you use to stick on a badge onto a car eg: the "integrale" badge on the tailgate ?
« Last Edit: 25 April, 2008, 11:22:32 AM by sparehead3 » Logged
Regards,
Steve Pilgrim
rogerelias
MY 1600HF IN HEARTBEAT GARAGE
« Reply #1 on: 09 April, 2008, 12:17:04 PM »
Hi . We use badge tape in our body shop, should be able to get from any good motor factors. Basically its  double sided tape, but about 1mm thick.
FULVIA 1600HF LUSSO
1958 VELOCETTE MAC
Triumph Bonneville t120v 1972
1968 MGC ROADSTER
1958 Series 2 Appia berlina
inthedark
« Reply #2 on: 09 April, 2008, 05:35:42 PM »
or if the badge had previously been removed and needs to be put back a few dabs of superglue
Geoff
« Reply #3 on: 09 April, 2008, 05:51:34 PM »
A paint shop got a roll for me of a 3M tape for holding on body mouldings and badges so it should be easily obtainable, just don't ever try to take the badge off again Grin it will probably take the paint with it, it's that good Shocked
sparehead3
« Reply #4 on: 09 April, 2008, 07:50:07 PM »
Thanks for the info chaps, I was kinda worried about the superglue but it had obviously crossed my mind !
I'm visiting a body shop so will see what I can get ...
Steve
Regards,
Steve Pilgrim
inthedark
« Reply #5 on: 09 April, 2008, 08:42:38 PM »
Steve,
the superglue route is only when there is residue on the car (from the old badge) and you're
putting the same badge back.
if it's a new badge then the double-sided foam is the only way, it comes on rolls 10 - 25 mm wide
and you will recognise it by the green plastic peel off strip. Don't use the other colours as they
all have specific uses. ask nicely at a local bodyshop and they may give you enough for the badge.
Geoff
sparehead3
« Reply #6 on: 10 April, 2008, 11:22:50 AM »
TVM Geoff!
Regards,
Steve Pilgrim
Scarpia
« Reply #7 on: 10 April, 2008, 04:27:39 PM »
quite an authority on double backed sticky tape...so that's what holds the moustache in position Colonel!
sparehead3
« Reply #8 on: 10 April, 2008, 06:33:16 PM »
& can use it to stick himself to walls when the legs give out Smiley
Regards,
Steve Pilgrim
inthedark
« Reply #9 on: 10 April, 2008, 09:20:41 PM »
I doo'nt need to stuck mysolf to tho wall I have a pefectely good flooor to hold onto
an my moosetache is not stuck in places it's perfectly happy on the fooor witfh me
Neil Lewis
« Reply #10 on: 11 April, 2008, 12:18:50 PM »
I've used EvoStik on my badges and it works really well.
You have to ensure that you coat both surfaces and wait until the tack has gone before putting the parts together.  And of course you only get one go at positioning the badge but thatr goes for double-sided tape too!
inthedark
« Reply #11 on: 11 April, 2008, 07:18:12 PM »
To be honest if you use proper bodyshop trim tape and don't press hard it can usually be moved
until you're happy then press hard and leave.
