30 December, 2024, 04:42:10 PM *
Author Topic: Mystery switch on Aprilia steering column  (Read 3843 times)
John Larkin
« on: 20 October, 2020, 03:06:23 PM »
I'm rewiring my 1949 Aprilia berlina from scratch.  There were too many different repairs and bodges just to carry out minor repairs, so I took photos and made notes, and then launched an offensive with wire snips.  I missed noting where the wire from one switch went, and I cannot trace it as many cables were made up of different-coloured wires joined along their length.  The switch looks as it it might be a contemporary after-market device.  It's a lever toggle switch of high quality and has one terminal only.  There are two positions, open and closed.  It completes a circuit through the switch body and the steering column, and so it earths some device.  I suspect that it may be a horn switch.  Does anybody recognise it?    There is logo inside:- CB, and a number:- 928. I've attached two images.
John Larkin.
John Larkin
« Reply #1 on: 20 October, 2020, 06:39:56 PM »
I've seen similar before, but used for dipping lights
I rewired my Cabrio from scratch adding a couple of circuits for modern side/brake lights etc (plus an iPhone charger option as well) - very satisfying
There is a chap in Italy making repro woven wiring that is very nice - takes longer to wire because it's all the same colour , but the end result is great
tzf60
« Reply #2 on: 21 October, 2020, 11:02:56 AM »
Hi John,
As you've suggested, maybe a horn switch to overcome the delicate original unit that mounts on the steering column? My bakelite unit has already already been repaired.......!!
Is the stalk switch spring-loaded?
Regards,
John Larkin
« Reply #3 on: 21 October, 2020, 12:59:20 PM »
Hi Tim,
The switch is not spring-loaded, so I suppose that makes it easier to give long blasts of the horn to annoy other motorists!
Regards,
John.
John Larkin
Raahauge
« Reply #4 on: 21 October, 2020, 07:18:05 PM »
Quite possibly an aftermarket item which the factory adopted with the Ardea, who's horn button can be turned about 30 degrees to lock it on, saves so much effort!
« Reply #5 on: 22 October, 2020, 09:59:29 AM »
Similar mounting to the'Bloster' steering blockers for Fulvia and Flavia, and certainly looks aftermarket fit to me.
John Larkin
« Reply #6 on: 24 October, 2020, 06:05:35 PM »
I've concluded that it is a dip switch.  It earths the coil in the headlamp changeover switch.
John Larkin
