23 December, 2024, 05:05:09 AM *
Pages: 1 [2] 3   Go Down
Author Topic: Float level  (Read 14177 times)
FERGTS246
« Reply #15 on: 05 February, 2021, 11:46:23 AM »
Hi, See Data sheet attached.
Excellent Chris, any chance of posting info from this data sheet. I for one have spent time trying to get things working properly. I have checked jet/ emulsion tube/ choke sizes etc. against info in my LMC workshop manual reprint. With my existing Solex, there is no positive 'stop' for the cold start device, although I think I have it correct with no whistling/frosting at the orifice. Richard
* 20210204111044.pdf (530.94 KB - downloaded 167 times.)
Richard Fridd
« Reply #16 on: 05 February, 2021, 04:17:58 PM »
Many thanks Chris, I haven't seen this particular sheet before in my service literature. I will translate to english text for quick reference.
Richard
Charles Frodsham
« Reply #17 on: 06 February, 2021, 10:22:16 AM »
Is this any use Richard?
Charles Frodsham
« Reply #18 on: 06 February, 2021, 10:23:04 AM »
Close up
Richard Fridd
« Reply #19 on: 06 February, 2021, 10:39:30 AM »
Many thanks Charles. I will have a look on a full size screen and print. Richard
FERGTS246
« Reply #20 on: 06 February, 2021, 10:56:26 AM »
Can I double check, this 18mm) distance is the measurement between fuel level and the machined top of float chamber body- not including the top casting (lid) where the needle jet is located?
Thanks Chris
Charles Frodsham
« Reply #21 on: 07 February, 2021, 10:40:47 AM »
That’s it.....”distance N is always intended from upper edge of the float chamber, gasket excluded, with tolerance of +/-1mm”.
Richard Fridd
« Reply #22 on: 07 February, 2021, 10:59:04 AM »
I see it now, at the bottom of the 'close up'. What does the 'N' actually stand for, anybody? Richard
FERGTS246
« Reply #23 on: 07 February, 2021, 01:55:42 PM »
Someone mentioned that the lid needs to be on the float chamber to measure the fuel level. Why is this?
Also, I've noticed that I've got a small outlet (hole) in one of my the chokes. It's covered by the choke valve when it's closed.
It's about 1mm diameter. I get a lot more carbon deposits in the side's exhaust tail pipe. See hole in picture attached.
« Reply #24 on: 07 February, 2021, 01:57:16 PM »
"Distance N mm" is the heading of the column that gives the measurement for each type of carburettor.
Charles Frodsham
« Reply #25 on: 07 February, 2021, 07:46:02 PM »
I’m not that familiar with the Solex single, as my car has the Solex triple P3 1/2. On the latter, the carb lid has to be in place because the float “needle valves” are mounted on it. It is the position of the float that acts on the needle valves that causes them to shut, hence resulting in a particular fuel level. i.e. if the float closes the valves earlier, the fuel level will be lower, and vice versa.
« Last Edit: 07 February, 2021, 08:06:28 PM by Charles Frodsham » Logged
Charles Frodsham
« Reply #26 on: 07 February, 2021, 08:04:55 PM »
If the inlet manifold is anything like a 3B manifold, it consists of a plenum chamber. So fuel/air from either of the 2 chokes (or 3 in my case) can feed any cylinder. So more soot in one exhaust pipe than the other is unlikely to be caused by the carb.......I think???
« Last Edit: 07 February, 2021, 08:09:03 PM by Charles Frodsham » Logged
Richard Fridd
« Reply #27 on: 07 February, 2021, 09:19:28 PM »
I think the PAAI has one common float chamber, but one idle and main cicuit per cylinder bank. And one common cold start device. Richard
FERGTS246
« Reply #28 on: 10 February, 2021, 05:49:43 PM »
Charles,
Thanks for this.
FERGTS246
« Reply #29 on: 12 February, 2021, 02:26:20 PM »
Just in case its of interest to a single carb Flaminia owner, my inlet manifold is separated down the middle, as far as I could see and feel.
Pages: 1 [2] 3   Go Up
Page created in 0.045 seconds with 21 queries.
