22 December, 2024, 02:25:22 PM *
Pages: [1] 2   Go Down
Author Topic: Aprilia boot floor board  (Read 8601 times)
John Larkin
« on: 11 December, 2020, 04:21:27 PM »
My 1949 Aprilia berlina is missing its wooden boot floor (over the spare wheel).  Has anybody got a photo of what this particular part should look like?
John Larkin
« Reply #1 on: 11 December, 2020, 04:36:57 PM »
I made one out of thickish MDF a few years ago - if you still have the starting handle it needs a notch out of the back edge
Sliding Pillar
« Reply #2 on: 11 December, 2020, 06:09:15 PM »
You will also need one of these........
1955 Aurelia
1961 Lamborghini
John Larkin
« Reply #3 on: 11 December, 2020, 07:54:54 PM »
Thank you both!
John Larkin
brian
« Reply #4 on: 12 December, 2020, 12:09:44 PM »
Good advice on both floor and prop. I had a similar stick but it was always in the way and so I have a 12" (approx) length of L-shaped aluminium strip that just fits in the top gutter so the arm on the lid rests on it and spreads the load such that the nascent hole in the gutter does not enlarge. So if plan to get fuel gauge working comes off, the need to go into the boot will hopefully reduce further.
Brian Hands
1922 Hands Tourer
1934 Augusta standard saloon
1938 Aprilia S1 saloon
1953 Aurelia B10
1965 Flavia Sport
tzf60
« Reply #5 on: 14 December, 2020, 01:50:31 PM »
The rails in Ade's picture seem higher that in Simon's photo. Is this another difference between Series 1 and Series2 ??
Tim F
tzf60
« Reply #6 on: 15 December, 2020, 01:39:40 PM »
Spot the deliberate mistake.....  Wink
Of course it dawned on me later that the Aprilia has two sets of rails.
Honest, it did!
GeoffJohnson
« Reply #7 on: 17 December, 2020, 04:23:46 PM »
Errr...
I've only got one.
Geoff Johnson
« Reply #8 on: 17 December, 2020, 06:23:07 PM »
My S2 only has 1 set of rails
Geoff, the curved cover on the inner wheel arch - is that to cover the André shocks ? Not noticed that before
« Reply #9 on: 17 December, 2020, 11:00:33 PM »
In a word, yes.
GeoffJohnson
« Reply #10 on: 18 December, 2020, 12:54:12 PM »
Yes.
 Here is a picture from underneath that I took when fitting that just about shows it in the top righthand corner
Geoff johnson
« Reply #11 on: 18 December, 2020, 03:09:11 PM »
There is a company in the UK that stocks virtually every part needed for the André shocks if you ever need any bits - but those on your car look great !
« Reply #12 on: 19 December, 2020, 10:35:41 AM »
Details are in the Technical Information thread pages 2 and 3 I think.
peterblenk
« Reply #13 on: 09 January, 2021, 05:11:12 PM »
My 1939 early Series II also has just one shelf, low down, just on top of the spare. I made a shelf out of 15mm marine ply, as I assumed it would get wet at some point. There was a hinged rod under the boot lid to prop open the lid, but a reinforcing fillet on the gutter, which is rather flimsy, would not go amiss. Good tip on the notch for the starting handle, but removing it would involve removing the shelf in the boot. I've been told it is actually a handle to set the valve timing. My question is - was there ever a rubber gasket on the boot opening? It seems to me that there must have been, or water would run into the boot through the slots for the boot hinge. If there was a rubber seal, did it go all the way around, and what section was it? Peter
« Reply #14 on: 09 January, 2021, 09:29:50 PM »
Yes, there is a rubber for the boot opening.   Also, I have started my car with the starting handle.
Pages: [1] 2   Go Up
Page created in 0.043 seconds with 21 queries.
