30 December, 2024, 05:05:12 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Model Technical and Interest
Fulvia
Series 3 coupe rear brake caliper hot
Pages: [
1
Go Down
« previous
next »
Author
Topic: Series 3 coupe rear brake caliper hot (Read 3395 times)
Oliveoils
on:
01 March, 2021, 12:22:05 PM »
The nearside rear wheel is warm after a short drive and gets hot following heavy braking. The Handbrake does not seem to be binding so suspect the caliper may be sticking on . This looks like the original when compared to the offside caliper .
Any advice from the experienced would be appreciated on this. Plans are to remove the caliper clean it up and fit new seals (depending on piston condition)
Where is the best source for a decent seal kit, are there any additonal parts I may need, and what pitfalls if any am I likely to encounter?
Do I just bite the bullet and buy a new / refurbished caliper?
Re: Series 3 coupe rear brake caliper hot
Reply #1 on:
01 March, 2021, 12:45:54 PM »
Depends on the piston and if you can loosen the bleed nipple. There should be a double tab washer for the 2 bolts holding the caliper and 2 shim washers between the caliper and the hub mounting holes. Not related to getting warm but are the correct pads fitted with the antisqueal shims and pad retaining springs. After many years these parts seem to go missing...
Try Omicron for a seal kit.
1998 Zeta 21. 12v
nistri
Reply #2 on:
01 March, 2021, 04:04:39 PM »
or try
northwestclassic@btinternet.com
, excellent UK company for quality brake parts, Andrea
Andrea Nistri
Ardea S2
Appia S2
Fulvia GTE
Fulvia Sport 1.3 S
Fulvia Montecarlo
Fulvia Coupe 1.3 S
Jaydub
Reply #3 on:
01 March, 2021, 08:29:00 PM »
I bought a complete kit from " Pieces Fulvia." very good prices. ( Pre Brexit)
1600 HF. S2.
Derek Creasy
Here's to sunnier days
Reply #4 on:
02 March, 2021, 08:58:03 AM »
I have a complete front axle repair kit for Girling brakes surplus to requirements . The smaller pistons on the front are the same size as your rears.
£20 the set inc Postage if of use
2000HF Coupe 1972
Fulvia Sport 1.3S 1968
Delta 3 2.0 Limited 2012
Oliveoils
Reply #5 on:
02 March, 2021, 05:29:20 PM »
Thanks very for the information guys, and the kind offer of parts which I will keep in mind. I removed the offending caliper today for an inspection and clean up. Pistons appear to be free with no leaks , but one certainly a bit tighter than the other. Cleaned of lots of accumulated crud from pad housings, back of pads /shims and replaced some very iffy and bent pad retainer split pins . Applied some copper grease to pads and re -assembled . I will now try the car for a few days and see what happens. Hoping that lack of use during lockdown has been the cause of the problem . which may resolve itself now by putting some miles on the car, but who knows....?
Crawling around under the car revealed both exhaust hangers are shot, so .... yet another job at the weekend B4 the MOT!
SJWhite
Reply #6 on:
05 March, 2021, 10:03:26 PM »
Incase it helps, had similar brake problems on JLT and discovered att.
Regards
Simon
JGV7N&JLT810N
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
