21 December, 2024, 02:17:48 PM *
Author Topic: 1970 Flavia Coupe 2000 - Petrol smell  (Read 4943 times)
msh2908
« on: 27 March, 2021, 06:31:18 PM »
Hi everyone,
I'm getting a powerful whiff of petrol in the cabin when I drive.  It gets stronger when the window is open - any thoughts?
Mark
neil-yaj396
Committee
« Reply #1 on: 28 March, 2021, 10:18:11 AM »
Could be any of your flexible fuel pipes. They fail from the inside due to the ethanol in modern fuel. If they are braided it is even worse as the braiding soaks up the leaking fuel. I'd try the under bonnet ones first if the smell is more obvious when driving, but be prepared to change them all if they are more that 4 or 5 years old.
« Reply #2 on: 28 March, 2021, 11:32:35 AM »
Also look under the mat/carpet in the boot in case the top of the tank has rotted out.
« Reply #3 on: 28 March, 2021, 11:33:08 AM »
Oh and stop driving it till you find the source of leak!!!
JohnMillham
« Reply #4 on: 28 March, 2021, 01:50:33 PM »
My 2000 Coupe sprung a huge leak years ago and flooded the engine compartment with petrol. I was very lucky it didn't catch fire, as it came out at high pressure and went absolutely everywhere! I stopped immediately, on a hill, and saw petrol pouring down the hill behind me. My lucky day!
bobhenry999
« Reply #5 on: 28 March, 2021, 02:18:26 PM »
I concur with Tim about it possibly being the top of the tank having rotted away, as I’ve had that on a number of Flavia/2000’s over the years.
Bob
Flavia 815 Vignale
Flavia 819 Milleotto
Flavia 815 Coupe Inezione
2000HF x2
2000 Coupe
2000 Sedan x3
GerardJPC
« Reply #6 on: 28 March, 2021, 05:11:23 PM »
Re Ethanol: if you have an Esso garage near you, Esso Supreme 99+ is ethanol free in many areas, but not all - the Esso website tells you which ones.
1962 Appia Berlina
1973 2000 HF Coupe
1978 Beta 1600 Coupe
1973 Fiat 124 Sport Coupe 1800
1981 Lotus Eclat S2
1982 Moto Guzzi V50 Monza
1982 Yamaha YB 100
1983 Land Rover SIII 88
2005 Alfa Romeo 156 Crosswagon Q4
2009 Jaguar XK 5.0
msh2908
« Reply #7 on: 03 April, 2021, 11:29:18 AM »
Thanks everyone.  The smell is only there when the windows are open - therefore the tank option sounds about right. There are no leaks or smells from the the engine bay. The breather system in the boot looks a bit 'Heath-Robinson' - does this cause problems?
Mark
Angle Grinder
« Reply #8 on: 05 April, 2021, 03:59:33 PM »
I have a strong petrol pong in the boot but there are no obvious pores in the top of the tank. In saying that, it is not unblemished a vapour will find a way through any mildly porous membrane.
In my case, I think it more likely to be the rubber gasket around the fuel gauge sender that is allowing the fumes out. Just need to find a supplier for a new one.
Previous cars:
1983 Prisma 1600
1991 Thema 16v i.e. SE
1988 Thema 8v Turbo
1992 Thema 16v i.e.
1983 Gamma Coupe (manual)
1993 Thema VIS
1994 Thema VIS LE
1990 Thema 2.8
« Reply #9 on: 05 April, 2021, 09:51:41 PM »
those gaskets are used by contemporary Italian cars like the Fiat 500. Ricambio springs to mind as a source
