If you want to remove the grill to make the job easier, then removing the rad makes sense….
I have the grill off the car. That is why I was asking because I can see all the bolts for the water pump and it doesn't look like they would be obstructed by the rad. I can pull the water pump out the hole where the grill was located. The manual does say to remove the grill and then the rad. Maybe that is applicable to the earlier 1.2's or maybe the S2?
S1 Berlina, you not only need to take the grille off which also means the air cleaner, the fan and pillar, loosen the dynamo.
The trim that goes all the way around the grille and headlamps, to get at the fixings on the passenger side you have to remove the air collector box .
Even then it's a fiddle to get the radiator out.
With the radiator in situ you can't even see the bottom hose and the hose clip.
It's what you could call a pig of a job
8227
