25 November, 2024, 12:32:37 PM *
Author Topic: S2 Sump/Oil Pan  (Read 4486 times)
RDG496
« on: 06 May, 2021, 08:44:26 AM »
I may need to source a new sump, when we last changed the oil it seemed the current one had been welded at one point and the threads on the sump plug required pfte tape and some sealer.
It does not leak at all but I suspect at one point a replacement may be needed.
Used is the best/only option ??
Are all Pans the same on the 1.3 whether S1 2 or 3 ?
« Last Edit: 06 May, 2021, 11:56:44 AM by RDG496 » Logged
Jai Sharma
« Reply #1 on: 06 May, 2021, 06:08:06 PM »
I think, but am not sure, that all the sump pans will fit.
There were a few that were a bit deeper, so presumably hold a bit more oil, I think these were on the very last cars but am not sure.
RDG496
« Reply #2 on: 06 May, 2021, 07:24:24 PM »
Thanks for coming back, I shall trawl the net....I'll find clarification somewhere !
Beckerman67
« Reply #3 on: 07 May, 2021, 07:05:58 AM »
 New one here https://www.ricambilanciafulvia.it/en/spare-parts-lubrification-system-lancia-fulvia/489-coppa-olio-fulvia-13.html
RDG496
« Reply #4 on: 07 May, 2021, 07:29:06 AM »
This is where I realise Fulvia ownership is not cheap
Eur 323
Also Front Wheel bearing, German Repro +140ish
Similar Alfa parts
GBP 135 and 24
I will source a used one I think, I can wait as its not leaking......yet !
Jaydub
« Reply #5 on: 07 May, 2021, 09:34:00 AM »
I would get the threaded hole welded up, drilled and rethreaded. Not too difficult if you know a good aluminium welder/machine shop.
1600 HF. S2.
RDG496
« Reply #6 on: 07 May, 2021, 11:14:34 AM »
If I can find a used one at a decent price I will buy it, if not I'll find a local welder and go that route.
Either way the last resort will be paying GBP300+ that's for sure !
Jay
« Reply #7 on: 07 May, 2021, 12:12:00 PM »
They do come up on ebay quite regularly
Julian Wood, Kingston, London
« Reply #8 on: 07 May, 2021, 12:33:49 PM »
Eur 323
Similar Alfa parts
GBP 135 and 24
Front wheel bearings have been selling for over £100 for at least the last 12+ years unless you were very lucky, but what a bearing , they make great door stops.
8227 : Cool
Beckerman67
« Reply #9 on: 07 May, 2021, 06:27:37 PM »
 https://www.ebay.co.uk/itm/274782211011?hash=item3ffa4bcbc3:g:67wAAOSw2XZgV0Jp
« Reply #10 on: 10 May, 2021, 08:48:47 AM »
Helicoil.
RDG496
« Reply #11 on: 11 May, 2021, 11:37:45 AM »
Bought that one on Ebay, will clean it up and install it...job done (I hope)!
