26 November, 2024, 12:34:02 AM *
Pages: 1 ... 5 6 7 8 9 [10] 11 12 13 14 15 ... 21   Go Down
Author Topic: Modestine  (Read 194347 times)
0 Members and 52 Guests are viewing this topic.
« Reply #135 on: 13 August, 2009, 12:52:15 PM »
My sister had a Mini called Ethel - based on its worth.
The Austin 7 Special is called Flora - after someone shouted that from the pavement in encouragement.   I know its a Lancia forum but I can't resist posting some snaps.  The black wheels 19in wheels with Blockley 3.5in tyres are relatively recent as the VSCC won't tollerate the radials anymore, and quite right too.  I waited until the Blockley was available to avoid motorbike tyres which give me the heebiegeebies.   The original radiator shell was made from a wok lid.  Twenty years on its STILL not finished, but conversely its still improving.
johnturner
« Reply #136 on: 15 August, 2009, 05:28:07 PM »
Robin
Really sorry to hear that, having been resurrected, Modestine has now shed her propellor shaft.  I wonder whether a sound thrashing a la Basil Fawlty would help.  The good news is that Lancia used standard Hardy Spicer couplings on the early cars, the company still operates as part of GKN in Birmingham, and Andy there is very helpful and can, or could until recently, supply companion flanges with the right keyway and taper off the shelf.  And he may be able to help with the re-machining of the output shaft.  A complete new shaft was made up for Arthur Keeling's Dilambda and Les will phone over the weekend to explain what was involved.
John
Dilambdaman
« Reply #137 on: 16 August, 2009, 10:02:39 PM »
Many thanks John, I'll follow that up.
Robin.
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
Dilambdaman
« Reply #138 on: 18 August, 2009, 11:54:01 PM »
Have spoken with Andy and Dave at GKN Driveline and they are pretty confident that they can effect a repair.
So, got the gearbox out this yesterday afternoon, opened it up and removed the damaged shaft. In the post to GKN today.
Good job I did open the gearbox up as the roller bearing immediately behind the damaged taper was full of metal filings and would have been knackered in no time.
Robin.
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
rogerelias
MY 1600HF IN HEARTBEAT GARAGE
« Reply #139 on: 19 August, 2009, 09:38:46 AM »
Can i slacken off a bit on the straps? Wink
FULVIA 1600HF LUSSO
1958 VELOCETTE MAC
Triumph Bonneville t120v 1972
1968 MGC ROADSTER
1958 Series 2 Appia berlina
Dilambdaman
« Reply #140 on: 13 September, 2009, 10:38:28 PM »
GKN Driveline built up and machined the taper on the gearbox output shaft and made a new propshaft flange to suit. All in a couple of weeks and at a very reasonable cost. Many thanks to John Turner for putting me on to them.
Re-assembled the gearbox on Saturday and hope to get it back in the car on Monday.
So, Roger, appreciate it if you could tighten the straps on your chair just until she's back on the road.  Wink
Robin.
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
rogerelias
« Reply #141 on: 15 September, 2009, 06:01:12 PM »
Me and the seat are orf to the broads for a week on friday, so no comments from here. but good luck
FULVIA 1600HF LUSSO
1958 VELOCETTE MAC
1968 MGC ROADSTER
Dilambdaman
« Reply #142 on: 17 September, 2009, 10:46:50 PM »
Well, I drove the Dilambda for a mile or so last evening but had great difficulty selecting 3rd and 4th gears. They have always been problematical but are much worse now. I was not totally confident that they were meshing fully when the gearbox was on the bench.
Otherwise everything else seemed fine apart from the water pump which is leaking badly again! Very good oil pressure still.
So, gearbox out again I'm afraid. Funeral to go to today, Goodwood Revival Friday so hopefully get to it on Saturday.
Robin
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
« Reply #143 on: 17 September, 2009, 11:00:14 PM »
There's something about getting a prize you really deserve - and when that car is running sweetly again...
rogerelias
« Reply #144 on: 18 September, 2009, 10:22:10 AM »
I am kinda getting used to this chair Wink Wink
FULVIA 1600HF LUSSO
1958 VELOCETTE MAC
1968 MGC ROADSTER
Dilambdaman
« Reply #145 on: 20 September, 2009, 02:12:21 PM »
The box came out yesterday and was stripped down and carefully re-assembled. Seems to operate OK now on the bench so back in the car this week hopefully.
Robin.
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
« Reply #146 on: 20 September, 2009, 09:43:51 PM »
Robin.
Robin,
any nasties in there Huh? or did it just need taking apart and putting back together again very carefully.
Dilambdaman
« Reply #147 on: 20 September, 2009, 10:07:52 PM »
Robin.
Robin,
No, no nasties in fact didn't find anything obvious that was causing the selection problem. So, fingers crossed until it gets road tested.
Robin.
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
Dilambdaman
« Reply #148 on: 24 September, 2009, 08:43:02 PM »
Box back in the car  (I'm really getting quite fast at that!) and a short test run went OK.
Whilst the box was out I had the sleeve on the bottom of the gear lever repaired which has improved gear changing enormously.
So, re-assemble the rest of the bits and pieces and indulge in some gentle longer runs.
Robin.
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
stuwilson128
Non-LMC Seller
« Reply #149 on: 24 September, 2009, 08:56:44 PM »
I really hope that you have finally solved the problems and can start to enjoy Modestine again  Smiley
Stuart Wilson 11175
1973 Fulvia Coupe 1.3
2000 Lybra SW 2.4JTd
2009 Delta 1.9 Twin Turbo
Pages: 1 ... 5 6 7 8 9 [10] 11 12 13 14 15 ... 21   Go Up
