Author Topic: Modestine  (Read 217869 times)
  • Permanent resident
Re: Modestine
« Reply #300 on: 05 April, 2020, 05:57:15 AM »
Degreasing - my favourite job !
What size are the pistons ? (Diametre of bore)
GG
  • Megaposter
    • Lancia Aurelia
Re: Modestine
« Reply #301 on: 05 April, 2020, 06:32:48 AM »
It even looks heavy.
  • Press Officer
Re: Modestine
« Reply #302 on: 05 April, 2020, 07:05:25 AM »
Could the rattle be timing chain flutter or something related as worn? Where do you get new sprockets.?
Dilambdaman
Re: Modestine
« Reply #303 on: 06 April, 2020, 12:54:27 PM »
Simon.  Bore diameter is 79.37mm. Some years ago a gudgeon pin circlip escaped and came up through the top of a piston! A new piston was required and Morris Parry researched his files and came up with a near match from a 1961 1.6 Ford Orion diesel engine! I picked up a set of four O/E on Ebay and with minimal modification they fitted and have been performing OK since. If I'm honest I would like to have the engined re-bored and a new set of pistons made. Eight of them and  expensive I guess.
Tim. Timing chain and sprocket wear is a real possibility and again as with the pistons if money were no object I would have new chains and sprockets. Dread to think what that would cost! The go to people are R M Fowler Ltd
http://www.chain-drive.co.uk/
Decisions, decisions.
Robin.
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
Re: Modestine
« Reply #304 on: 12 April, 2020, 11:08:13 AM »
You might be lucky enough to find some of the right size yet.   Do be sure that they weigh the same as the originals of course, narrow Vengines are notoriously difficult to balance (see Lambda technical information thread).
Re: Modestine
« Reply #305 on: 12 April, 2020, 08:56:20 PM »
One place to ask.  Any others?
https://www.fwthornton.co.uk/pistons
Dilambdaman
Re: Modestine
« Reply #306 on: 12 April, 2020, 10:52:01 PM »
Thanks David and David.
Robin.
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
