Well, another 8 hours, this time with son Jonathan and still no nearer solving the problem. Investigated inside of the bell housing with Jonathan's Fire Brigade Search and Rescue fibre optic camera, amazing what you can see! Sump off, faced off the heads of the flywheel bolts as they seemed to be running very close to the rear of the block and checked conrod to cylinder liner clearance. Ran the engine having removed push rods on each cylinder to see if valves were the problem. Head off, camshaft out but all looked fine.
Re-assemble now and run again. Think that I'll trailer her to the AGM so that you can all have a listen! Bring your overalls!
Robin.
