22 December, 2024, 01:39:06 AM *
Author Topic: 1970 Flavia Coupe 2000 - Clutch  (Read 3836 times)
msh2908
« on: 17 May, 2021, 01:53:34 PM »
Hi everyone,
My clutch friction plate needs replaced, so I was wondering if this can be done by removing the gear box from underneath.  I suspect this is the case, but would appreciate the views from those more knowledgeable.
With thanks.
« Reply #1 on: 17 May, 2021, 04:08:43 PM »
That is probably the best way. If you do not have a ramp then you will need very tall /large axle stands a trolley jack with a transmission cradle. Depending on the type of gear box you may well need to remover the remote shift before dropping the box... Allow at least 2 days to get the box out and 2 to put back.
alan284flavia
« Reply #2 on: 21 May, 2021, 04:21:04 PM »
Was also pondering the same question. I have a better gearbox to install and should do the clutch, mine is on 60000 miles and has pretty long travel. Can anyone confirm the clutch diameter, I have had one supposedly listed for Flavia 2000 but would like to be certain
« Reply #3 on: 22 May, 2021, 07:49:41 AM »
exactly what Flavia?? Chassis number ?
alan284flavia
« Reply #4 on: 30 May, 2021, 07:51:46 AM »
It is the short run model Flavia 2000 with what is called the big 4 speed gearbox. Ran from 1969 to early 1971 when Flavia name was dropped. Do not have chassis no to hand
« Reply #5 on: 30 May, 2021, 09:01:58 AM »
It is possible that it is 215mm as later 2000 five speed
Brian Long
« Reply #6 on: 25 June, 2021, 06:34:38 AM »
...and I think from memory that the plate is installed 'back-to-front'. Check orientation of existing plate when you remove it.
Page created in 0.051 seconds with 21 queries.
