25 November, 2024, 01:42:06 AM *
Author Topic: Fulvia accelerator roller bearings  (Read 3530 times)
Justin McArdle
Fulvia Berlina 2C
« on: 29 June, 2021, 01:03:40 PM »
I need to change the two nylon wheels behind the accelerator pedal as they expand on hot days and the pedal sticks.
What size roller bearings are required as replacements.
Lancia 2000 HF Coupe
Fulvia Berlina 2C
D5177_55A
« Reply #1 on: 29 June, 2021, 03:35:46 PM »
626 bearings. 6mm wide; 19mm outer diameter. 6mm ‘hole’. Don’t forget to ‘hand-bend’ the channel back to shape as well.
https://www.bearing-king.co.uk/bearing/626-2rsh-skf-sealed-deep-groove-ball-bearing-6mm-bore/3569
my69S1
« Reply #2 on: 29 June, 2021, 03:39:14 PM »
Also these.  Same size.
https://www.bearing-king.co.uk/bearing/626-2z-skf-shielded-deep-groove-ball-bearing-6mm-bore/3570
Justin McArdle
Fulvia Berlina 2C
« Reply #3 on: 29 June, 2021, 07:00:09 PM »
Thanks everyone
Fulvia Berlina 2C
« Reply #4 on: 29 June, 2021, 07:46:17 PM »
Thanks everyone
Justin you notice the difference!
robupton
« Reply #5 on: 06 July, 2021, 10:41:21 PM »
Good timing! I was just looking at my accelerator pedal yesterday and wondering why it was flopping around. I thought something must be missing and I guess it must be those bearings!
A related question - at the  other end of the throttle cable my cable goes around the 'post' and is secured in a temporary looking way. How is the engine end of the cable supposed to attach?
1974 Fulvia Coupe Monte Carlo
1963 Flaminia PF Coupe
« Reply #6 on: 08 July, 2021, 05:41:30 AM »
Original equipment had a “rubber” bush. These ball bearings replace those.
On the question off throttle cable depends the the midel if car….
