Author Topic: Fulvia accelerator roller bearings  (Read 4546 times)
Justin McArdle
  • Megaposter
  • Fulvia Berlina 2C
« on: 29 June, 2021, 01:03:40 PM »
I need to change the two nylon wheels behind the accelerator pedal as they expand on hot days and the pedal sticks.
What size roller bearings are required as replacements.
Lancia 2000 HF Coupe
Fulvia Berlina 2C
Thema 8.32 S2
Lancia 2000 Sedan
D5177_55A
  • Member
Re: Fulvia accelerator roller bearings
« Reply #1 on: 29 June, 2021, 03:35:46 PM »
626 bearings. 6mm wide; 19mm outer diameter. 6mm ‘hole’. Don’t forget to ‘hand-bend’ the channel back to shape as well.
https://www.bearing-king.co.uk/bearing/626-2rsh-skf-sealed-deep-groove-ball-bearing-6mm-bore/3569
my69S1
  • Lapsed
  • Member
Justin McArdle
  • Megaposter
  • Fulvia Berlina 2C
« Reply #3 on: 29 June, 2021, 07:00:09 PM »
Thanks everyone
Fulvia Berlina 2C
Thema 8.32 S2
Lancia 2000 Sedan
  • Permanent resident
« Reply #4 on: 29 June, 2021, 07:46:17 PM »
Thanks everyone
Justin you notice the difference!
8227 8)
robupton
  • Member
« Reply #5 on: 06 July, 2021, 10:41:21 PM »
Good timing! I was just looking at my accelerator pedal yesterday and wondering why it was flopping around. I thought something must be missing and I guess it must be those bearings!
A related question - at the  other end of the throttle cable my cable goes around the 'post' and is secured in a temporary looking way. How is the engine end of the cable supposed to attach?
1974 Fulvia Coupe Monte Carlo
1963 Flaminia PF Coupe
  • Press Officer
« Reply #6 on: 08 July, 2021, 05:41:30 AM »
Original equipment had a “rubber” bush. These ball bearings replace those.
On the question off throttle cable depends the the midel if car….
