25 November, 2024, 02:42:06 PM *
Author Topic: Brake fluid  (Read 3082 times)
« on: 13 July, 2021, 01:43:43 PM »
Am I correct in thinking standard brake fluid for Fulvia systems is Dot 3.
Any recommendations for supplier please.
« Reply #1 on: 13 July, 2021, 02:40:27 PM »
I only use dot 4 or silicon dot 5. Dot 3 is compatible with dot 4 and dot 4 has a much higher boiling point than dot 3.....
« Reply #2 on: 13 July, 2021, 04:07:06 PM »
I always use Dot 4 in our old cars and never have anything else on my shelves. I avoid silicon fluid only because i dont want to run into possible trouble with mixing fluid and consequent seal problems.
« Reply #3 on: 13 July, 2021, 04:10:26 PM »
Many thanks Gentlemen,  Dot 4 it is.
« Reply #4 on: 13 July, 2021, 09:07:51 PM »
only use silicon fluid on cars that are dedicated to that. I.e they have never seen glycol based Dot 4 etc.
« Reply #5 on: 19 July, 2021, 02:36:06 PM »
I've now a bottle of Dot 4 but it says it's synthetic, so I'm now confused is it safe to use? my old tin of top up brake fluid was lockheed/Girling, and I have no recollection if it was synthetic, come to that, I wonder what the garage used the last time they changed the brake fluid Huh?
« Reply #6 on: 19 July, 2021, 03:50:49 PM »
Brian, modern DOT4 is synthetic these days it is not the fully synthetic or silicon type fluid you can't mix, it should not be a problem.
« Last Edit: 19 July, 2021, 05:51:58 PM by Neil » Logged
386
1973 Fulvia S2 1.3
« Reply #7 on: 19 July, 2021, 04:14:35 PM »
Brian, modern DOT4 is synthetic these days it is not the fully synthetic or silicon type fluid you can't mix, it should not be a be a problem.
Thanks Neil.
