DELTONA
« on: 15 July, 2021, 09:18:57 AM » |
Has the original ‘Dunlopillo’ foam in your front seat bases deteriorated? A simple test is to lift the base out of the seat frame and feel the foam through circular access holes, if the foam is brittle and crumbles then this is the sign the foam has lost its integrity. I have approached a local foam supplier ( https://interfoam.co.uk ) who happens to be one of the UK’s premier providers of high quality, moulded polyurethane foam products and are happy to look into reproducing these bases. The bases will be made from Polyurethane Moulded Foam. Manufactured and tested to FMVSS 302. Comfort and density will match automotive industry standard and calibrated to be the same as the original Fulvia bases. Prices would likely to be no more than £70 per base. I am looking to have a batch produced and wanted to ask if anyone would be interested?
1993 LANCIA HF integrale | 1969 LANCIA Fulvia Coupe 1.3 Rallye S | 1972 FIAT 695 Elaborazione ABARTH | 1982 FIAT 127 1300GT | 2005 Alfa Romeo 147 GTA | 2010 Alfa Romeo 159ti TBI
« Reply #1 on: 15 July, 2021, 09:49:50 AM » |
Has the original ‘Dunlopillo’ foam in your front seat bases deteriorated? A simple test is to lift the base out of the seat frame and feel the foam through circular access holes, if the foam is brittle and crumbles then this is the sign the foam has lost its integrity. I have approached a local foam supplier ( https://interfoam.co.uk ) who happens to be one of the UK’s premier providers of high quality, moulded polyurethane foam products and are happy to look into reproducing these bases. The bases will be made from Polyurethane Moulded Foam. Manufactured and tested to FMVSS 302. Comfort and density will match automotive industry standard and calibrated to be the same as the original Fulvia bases. Prices would likely to be no more than £70 per base. I am looking to have a batch produced and wanted to ask if anyone would be interested? Thank you, I'd certainly be interested in one, but is it only for Coupe? As I think it might be different for series 1 Berlina. Brian 8227
DELTONA
« Reply #2 on: 15 July, 2021, 01:13:02 PM » |
Hi Brian, from what I can see from images online the Berlina seat bases do look different to the Coupe so it may not be suitable, but I am sure the experts amoung us here can confirm.
Many thanks Pep
cyborg7
« Reply #3 on: 15 July, 2021, 09:47:42 PM » |
Yes definitely interested thanks
DELTONA
« Reply #4 on: 15 July, 2021, 10:24:30 PM » |
Ok Chris, that’s 4 people interested - many thanks will be in touch
nistri
« Reply #5 on: 16 July, 2021, 06:24:31 AM » |
Interested for a friend currently restoring an early S1 coupe. Suitable for mailing it to Italy? Andres
Andrea Nistri
DELTONA
« Reply #6 on: 16 July, 2021, 10:49:33 AM » |
Hello Andrea, yes shipping to Italy is not an issue if your friend is happy to pay for the shipping. Thats great, I now have 5 people interested, the more numbers I get the more this becomes viable.
« Reply #7 on: 16 July, 2021, 11:23:13 AM » |
A few years ago, I had the seat squabs of our GTE re-foamed by a local trimmer here in NE Italy. He did a lovely job cutting the foam from a block and completely restitched the squabs as well for €100 for the 2 but funnily enough the new foam was too stiff and Jacky and I both sat a bit too high. Some modification was subsequently needed. Can I therefore suggest you do some sort of 'dummy run ' with one squab to double check you dont have this problem. Specifications for foam are one thing but comfort and location of seating are paramount to driving pleasure. Chris
DELTONA
« Reply #8 on: 16 July, 2021, 12:11:21 PM » |
Hi Chris, noted and yes I will of course be testing the prototype if this becomes viable. Although something tells me everyone will have an opinion and like most things you cannot please everyone. Interfoam can of course make the foam to different tolerances and I would be edging towards the softer more comfort side of things.
Jaydub
« Reply #9 on: 16 July, 2021, 04:39:48 PM » |
Hi I am interested as well please.
1600 HF. S2.
DELTONA
« Reply #10 on: 16 July, 2021, 05:03:18 PM » |
Many thanks, noted will be in touch if we get enough numbers.
Kind regards Pep
nthomas1
« Reply #11 on: 17 July, 2021, 07:27:50 AM » |
Giuseppe - would you add me to the list please. many thanks, Norm
Norm Thomas Ormskirk, Lancashire
Own: 1973 Fulvia S2 Coupe Previous Lancias: S2 Coupe and S3 Coupe in late 1970s
DELTONA
« Reply #12 on: 17 July, 2021, 09:08:14 AM » |
Hi Norm, yes if course. Thanks
cbudden
« Reply #13 on: 17 July, 2021, 01:02:17 PM » |
Good afternoon, I too would be interested in a pair - grateful if you would add me to the list. Best regards Chris
EVOCCR
« Reply #14 on: 17 July, 2021, 08:43:50 PM » |
Yes a pair for me please.
