I also had an electric fuel pump go bad 3 years ago - symptoms were erratic. Carb ran out of fuel, then everything was fine for an hour, or a day! After checking everything else, only the pump remained as a possible cause (it was however still making all the right noises!).
After changing it for a new one, problem was solved. Since then I have put two electric pumps in parallel and can switch from one to the other. On that Lancia there is no mechanical pump!
Sounds a good idea. Do you have photo of how your parallel pumps are mounted, as I have seen some professional looking brackets/ banjo type fittings for cylindrical style twin pumps.
Richard
