26 December, 2024, 02:38:00 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
Model Technical and Interest
Lambda
Front wheel bearings
Pages: [
1
Go Down
« previous
next »
Author
Topic: Front wheel bearings (Read 2343 times)
on:
29 September, 2021, 02:07:50 PM »
Need new ones for the VIIth. To save me dismantling first, rollers with axial (one way or two way?) location or balls? Or a mixture of both?? I have measured from empty hub and stub axle that they need to be 35x72x17 and and 25x52x15. I have no idea if the ones installed are right anyway. Thanks in advance.
Dikappa
Re: Front wheel bearings
Reply #1 on:
30 September, 2021, 11:22:01 AM »
Hi David, standard deepgroove ball bearings 6207 (35x72x17) and 6205 (25x52x15)
Axial roller bearings in between are not supplied any longer as far as I know, but most re-use them or omit (as modern bearings have deeper grooves and can cope with axial loads much better. In the latter case a special distance bush is to be turned up to replace the axial bearings and bushes in between them.
If you re-use your original axial bearings (most of the time they are in prefect condition) you could order 2RS versions of the above bearings and just flip out the seals at the inner side of the bearings.
Tony Stephens
Reply #2 on:
02 October, 2021, 08:54:04 PM »
Or you could buy original spec replacements which are a listed Consortium spare. OK, getting special Lambda bearings is expensive, but they are beautifully made by a specialist F1 supplier, and you don't need to buy them every week.
Also, on the "don't use it, then lose it" principle, I think we should support Consortium manufacture of special Lambda replacement spares. The profit margin is small, non-commercial, and simply helps us to maintain stocks of those items which cannot be substituted. (Well, he would say that, wouldn't he?)
And you can just look in the Consortium list, order them, and they arrive by post. Come on,fellas!
Reply #3 on:
10 October, 2021, 05:19:15 PM »
In the end I fitted new deep groove ball bearings and re-used the axial bearings which were in excellent condition. I had trouble with the inner race retaining ring that, on one side, would only go in a couple of turns one one of my spare hubs (would not go at all on the original) even after carefully cleaning the threads with my thread file, so I consulted my engineering wizard friend John Baxter who told me the trick. Coarse valve grinding paste and patience will eventually result in a thread that works perfectly. I did this on the hub of four into which I had the best start, then turned it over and beheld the hub cap thread - left hand thread. A moment of heart stop until I realised it is for the right hand wheel...
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
