21 December, 2024, 01:27:28 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
Model Technical and Interest
Fulvia
Gearbox removal advice
Pages: [
1
Go Down
« previous
next »
Author
Topic: Gearbox removal advice (Read 2248 times)
jus
on:
05 October, 2021, 09:15:20 PM »
Hi all.
Just after a bit of advice regarding gearbox removal. Ideally, I would like to take the box out without removing too much else. This is a S1 HF with a 630 box that has straight cut gears, and is currently geared very low.
I'm hoping to swap out the final drive from a donor box, because as it is, the car does around 10mph per 1k rpm in 5th, which makes it pretty tough to take any distance. I intend keeping the current box in because I know it's all good, but just want to alter the final gearing. A part of the case has a big graze and leaks a bit of oil, so I want to change that as well.
The donor box is of the same type (a 630), but had a rusted input shaft that didn't move. It may be that I can't use the internals, but the case would still be worth having.
Any advice would be much appreciated. Of course, I could get it done - but I prefer to do things myself if possible.
I've had a look around the forum, but if I've missed the relevant information - please point me in the general direction.
Thanks,
Justin.
1969 S1 Fulvia 1.6
1971 Ex-works Fulvia 1.6
1975 Gr4 Stratos HF
1982 Beta Spyder
1982 037 Rally
Re: Gearbox removal advice
Reply #1 on:
06 October, 2021, 06:37:34 AM »
You can remove the gearbox leaving the engine in place. Either on a ramp with a transmission jack or on very high axle stands (my preferred method if honest) and a 2ton trolley jack with a transmission cradle). You will need another jack to support the engine while gearbox is removed/out. A 4 post lift is in some respects easier to do this work than a 2 post from my experience with Fulvia layout.
One thing to remember is to do all the engine bay work before the car goes in the air! You will have to remove the exhaust manifold and down pipe….
1998 Zeta 21. 12v
jus
Reply #2 on:
06 October, 2021, 11:02:41 AM »
Thanks Tim.
I do have a 4-post but I need a transmission jack by the sounds of it. I keep meaning to get one anyway. The lift has a rolling jack which will hopefully do for the engine support.
I think I've seen some posts on gearbox stripping down - so I'll have a good look at anything I can find before taking one apart - but at least I have this donor box to take apart first. I guess the boxes are relatively similar across the various models?
Cheers,
Justin.
1969 S1 Fulvia 1.6
1975 Gr4 Stratos HF
1982 Beta Spyder
1982 037 Rally
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
