I've just had this email exchange with a fellow Lancia man, and it gives me the opportunity to emphasise that I don't think ill of Paul Atkinson at all. Just for the record.
On Sat, Oct 5, 2024 at 6:37 PM [...] wrote:
Hello Mark,
I don't own an Augusta, but I used to look after [one]. I have been reading your posts on the LMC forum with interest. The poorly done crash repair to the front end sounds awful. I knew Paul Atkinson quite well, but mostly through his ownership of a Lambda and I can't see him being responsible for such a bodge. Do you think it was done during his ownership, or someone else? I'm just curious because I don't want to think badly of a man of whom I had a high regard.
Whatever, I am sure you will enjoy your car.
Best wishes,
Hello [...],
I simply don't understand it.
I mean to do the job properly would take thousands of pounds. So perhaps it was the case that they couldn't afford to do it, and that what we have is the best they could do - or have done for them. Fair enough.
And I have to be honest, with the amount of money I've had to spend to bring the car back into commission (and that's with Chris McPheat charging me mate's rates!) there's no way known that I could afford to have it repaired as-new either. Because to do that means two entirely new wings. So I'm not criticising Paul there.
As I say, it wasn't visible so much until we took the bumper off... And it won't be very visible again when the new stone guard and number plate (that extends 'through' the starting handle area and fills in the V at the bottom) is done. Because that will 'centre' the eye.
We think it must have had a fairly large thump, but it didn't damage the chassis. Perhaps it was driven into a wall or a fence at 10mph or so? That's all it would have taken. Remember the left suspension small spring was broken and most impressively, the lower guide was cracked. That takes some real doing, coz they are hewn of solid rock... [And I should add, too, that two wheels were very badly buckled, one centre and one rim were beyond repair.]
By the way, I've had to spend money on the new lower dashboards (rather than on going towards new wings for example), because I have MS. MS renders the body incapable of effectively controlling heat, which means if I get a build up of heat I start to feel unwell. Without auto-climate I must monitor the external and internal ambient temperatures to be proactive about opening windows early. This means two gauges extra, to go in below the clock, plus a lovely St Christopher I found on Colin Warrington's Old Motors stall at the Prescott Long Course meeting last weekend. Really pleased with how the new lower dashboards are coming together; instead of being simply tacked on, they'll look like they were a bespoke order made in the factory - as do the direct air inlets :-)
As Stuart Roach said to me, she's an old lady showing her adventures! He advised me not to repair a small star crack in the paint on the right mudguard because that's just lovely patina. Which it is actually, just adds character.
Anyway, you'll be able to see it all on the VSCC stand at the Classic Motor Show.
All best cheers,
