22 December, 2024, 01:56:36 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Model Technical and Interest
Aprilia, Ardennes and Ardea
Aprilia Voltage Regulator
Pages: [
1
Go Down
« previous
next »
Author
Topic: Aprilia Voltage Regulator (Read 2446 times)
DavidHill
on:
11 December, 2021, 06:39:03 PM »
Hi,
I am confused as to whether my voltage regulator is working and whether I have wired it correctly. It is a Bosch regulator 9190 040 099 and currently when I run the car there is around 16-18V at the battery terminals when the car is running at around 1000 rpm. All the advice on the internet states that over 14V is too high and could damage the battery. I have tried two other Bosch regulators and get the same voltage at the battery (16-18V)...is that the right voltage or do I need to change something?? I have connected B+ to the battery, 61 to the fuse box and D+ and DF to the Dynamo.
David.
Re: Aprilia Voltage Regulator
Reply #1 on:
11 December, 2021, 09:36:26 PM »
Are you using a digital voltmeter? If so Try an analogue one - they are much more resistant to hi RFI under the bonnet of an old car ignition system
1998 Zeta 21. 12v
Reply #2 on:
11 December, 2021, 10:38:31 PM »
These old regulators can be adjusted as well. There are two circuit breaker springs within, one for the cut out and one for the voltage. They are tensioned by adjustable screws. By trial and error you can work out which is which! Normally you would want 14.7 volts across the battery terminals.
DavidHill
Reply #3 on:
12 December, 2021, 09:21:38 AM »
Thanks for the replies on this. I don't think the regulator needs adjusting as I have also tried a Bosch solid state regulator with the same results - I still get 16-17v at the battery. I am using a digital multimeter though...interference from the engine does make sense as when I put the multimeter on top of the engine it does go haywire! (It is much more stable on top of the battery). I will try and borrow an analogue one and see if that reads 14v. Will keep you updated!
DavidHill
Reply #4 on:
13 December, 2021, 06:10:59 PM »
Found the issue. I made a small faraday cage to put the multimeter in and it still showed 16-17v, so discounted interference. I then unbolted the voltage regulator completely from the dynamo and isolated it from it (but it was still wired in). That fixed it! Essentially the dynamo is transmitting unregulated voltage to the B+ output via its casing and the attachment bolt...so all i need to do now is attach the regulator but make sure it is not attached with anything that conducts ... Thanks for all the advice!
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
