30 December, 2024, 05:30:46 PM *
Pages: 1 [2]   Go Down
Author Topic: Starting during winter lay-up  (Read 6672 times)
Wangler
« Reply #15 on: 04 January, 2022, 09:32:46 AM »
Would a petrol priming bulb work?
Thank you for that excellent suggestion. I've now done away with my rather Heath-Robinson setup and put in a bulb between the metal fuel line where it enters the engine compartment and the standard fuel pump - it works a treat. I'll probably take it off when I start to use it on the road in the spring, simply because it's something that could go wrong as it's only a cheap rubber component.
Fulvia Coupe 1976
Fulvia Coupe 3 1975
Richard Fridd
« Reply #16 on: 04 January, 2022, 10:01:58 AM »
Thank you for the conformation. I will try and keep the idea in the memory. Does it require many pumps? I suppose if it has a non return valve and is near to the carbs that would help. Although a 'near to the carbs' position can obviously get hot. Do you have a photo to post? Richard
Wangler
« Reply #17 on: 04 January, 2022, 12:12:00 PM »
There you go!
Only needs a few squeezes. I'm sure there must be a non-return valve but I wouldn't think it could be relied upon to make a good enough seal if you were to leave the car for a few weeks.
* 77017982-DF7E-45CF-9A00-91606774C7AC_1_201_a.jpeg (2913.33 KB, 2928x3114 - viewed 151 times.)
Fulvia Coupe 1976
Fulvia Coupe 3 1975
« Reply #18 on: 05 January, 2022, 02:12:26 PM »
There you go!
Friend in the Netherlands leaves his in place all the time and he's never mentioned it leaking, it seems to be a popular fit there.
However I still prefer the electric pump fitted just in front of the furl tank about 5 years ago , although I recently had the fuel hoses to and from it changed, as they were leaking .
nistri
« Reply #19 on: 06 January, 2022, 12:45:37 PM »
Good quality fuel hoses now carry a stamped date on them (like tyres) to indicate their manufacture date. Worth replacing them after 5-7 years with modern petrol usage, Andrea
Andrea Nistri
Ardea S2
Appia S2
Fulvia GTE
Fulvia Sport 1.3 S
Fulvia Montecarlo
Fulvia Coupe 1.3 S
Pages: 1 [2]   Go Up
Page created in 0.044 seconds with 21 queries.
