24 December, 2024, 01:06:21 AM *
Author Topic: Pole type fuel senders  (Read 4287 times)
« on: 01 January, 2022, 05:06:34 PM »
Has anyone here tried one of these with the standard fuel guage. Zero to 180 ohms available locally (Carbuilder)with various heights to choose from. Richard
« Last Edit: 02 January, 2022, 08:14:32 AM by Richard Fridd » Logged
Brian Long
« Reply #1 on: 03 January, 2022, 10:08:50 AM »
The Flavia2000Consortium had a few articles on converting to these level senders a couple of years ago.
You might chase them up.
« Reply #2 on: 03 January, 2022, 11:19:26 AM »
Excellent Brian, anyone here know if there an article available? Could be invaluable prior to proceeding. Richard
« Last Edit: 03 January, 2022, 01:34:07 PM by Richard Fridd » Logged
Brian Long
« Reply #3 on: 04 January, 2022, 03:07:16 AM »
I am away from home for a while so can't dig out the subject article.
Basically you have to ensure that the empty-to-full resistance change in the new sensor is the same as in the original one.
The new one states '180 ohm'. If you have a multimeter you can check what the resistance of the winding in the original sensor is.
Although I haven't tried it, you could temporarily connect the new sensor and immerse the float portion in a jar of water to see how it matches up with the gauge indication.
FERGTS246
« Reply #4 on: 04 January, 2022, 11:33:08 PM »
Hi Richard,
I had my original sender repaired by someone. I think his name was GaugeMan or something similar.
I found this information about original sender at:
www.classiclancia.com/car-parts/flaminia-petrol-tank-buoy-flotter-boa
OHM range: 4/4 tank: 10 Ohms = approx.
OHM range: 1/2 tank: 100 Ohms = approx.
OHM range: (nearly) empty: 300 Ohms = approx.
Length (total): 260 mm
Original parts
Fuel gauge - Jaeger  76278 29 25097 002
Tank Sender - Jaeger 39/77990/01
« Reply #5 on: 07 January, 2022, 06:39:20 PM »
Thanks Chris, I expect the locally available one I had in mind would read 'empty' at the half way level, but the 250mm depth seems suitable, having measured my tank, narrowly avoiding internal obstructions. Fuel level always seems low when I look in there, similar to your recent thread, although 20 miles per gallon? (Twice round my test route and ten minutes shuffling back into my garage). Richard
« Last Edit: 09 January, 2022, 07:35:25 AM by Richard Fridd » Logged
Charles Frodsham
« Reply #6 on: 24 February, 2022, 07:38:26 PM »
Is this any use? Looks like a current reproduction from M.A.R.A.
https://mara.it/en/shop/flaminia-en/alimentazione-e-scarico-flaminia-en/fuel-tank-sender/
« Reply #7 on: 24 February, 2022, 09:36:24 PM »
Looks very good, thank you. Richard
Charles Frodsham
« Reply #8 on: 25 February, 2022, 11:07:57 AM »
Let me know how it goes Richard…..I could do with one myself!
« Reply #9 on: 25 February, 2022, 06:54:33 PM »
 I have sent a request, regarding cost and availability. Richard
« Reply #10 on: 28 February, 2022, 07:42:14 PM »
Reply now received. The cost is €280, plus taxes and shipping. Richard
« Last Edit: 01 March, 2022, 11:06:10 AM by Richard Fridd » Logged
FERGTS246
« Reply #11 on: 01 March, 2022, 02:13:36 PM »
Well I suppose duty, taxes and deliver will ad another €100!
I hope its super accurate for you.
Charles Frodsham
« Reply #12 on: 01 March, 2022, 07:25:14 PM »
That sounds a bit excessive…..I think the equivalent Fulvia item is €105+vat.
How about trying out friend in NL….
https://www.classiccartuning.com/car-parts/flaminia-petrol-tank-buoy-flotter-boa
It should be a good solution, but no idea on price. It’s almost worth it for the description “buoy-flotter-boa”
Is there enough interest to buy a small batch for members? I could be interested.
« Last Edit: 01 March, 2022, 07:27:03 PM by Charles Frodsham » Logged
