30 November, 2024, 11:33:47 AM *
Author Topic: Series 2 Engine Support  (Read 3407 times)
V8estate
« on: 14 January, 2022, 02:56:11 PM »
My engine support is missing. I have seen this which I am going to purchase.
I wanted to know if there is anything that fits on the subframe,( rubber bush for example ) or is this the complete support
thanks in advance
« Reply #1 on: 14 January, 2022, 03:42:07 PM »
It also needs a nut to lock it on the sidearm. The manuela says the clearance from the subframe should be about 2 mm, Andrea
V8estate
« Reply #2 on: 14 January, 2022, 04:24:44 PM »
Thank you. So there is nothing that fits on the subframe?
« Reply #3 on: 14 January, 2022, 04:33:34 PM »
Not on Series 2 - assume you have the arm that bolts from  the crankcase below the alternator?
I may have a  new old stock item. PM me if  interested.
V8estate
« Reply #4 on: 14 January, 2022, 04:39:54 PM »
Yes I have the arm. I also have the threaded support but it has no rubber on the end, so need a new one of these.
If you have one, I would be interested as I was going to buy one from Italy
« Reply #5 on: 14 January, 2022, 04:54:05 PM »
Relatively easy to find some thick rubber (4-5mm) and bond it with superglue....
V8estate
« Reply #6 on: 14 January, 2022, 05:50:01 PM »
Yes, I thought that as i was writing my reply to you!
« Reply #7 on: 14 January, 2022, 05:52:42 PM »
                       s1 has a subframe mounting I think
Wangler
« Reply #8 on: 14 January, 2022, 10:07:56 PM »
Mine didn’t have the rubber buffer on it so I used a cotton reel type exhaust mount and cut a section of it out using an electric drill to spin it and a stationary hacksaw blade to cut it. Use flexible glue to stick the resulting pad on to the screwed unit.
Fulvia Coupe 1976
Fulvia Coupe 3 1975
« Reply #9 on: 16 January, 2022, 08:51:38 PM »
Yesterday I inspected an ex Italian ex South African series 1 1.3 Rally S or dating purposes..
The engine steady was bolted to the subframe, different to the one referred here, with the rubber pad, the same as on my 2c.
And casting my mind back over 20 years ago, I seem to remember the one on my 1969 RHD UK 1 3 Rallye Coupe was the same.
8227
 Cool
Page created in 0.08 seconds with 20 queries.
