21 December, 2024, 04:59:45 PM *
Author Topic: Routing of wiring loom 4th series B20  (Read 1936 times)
impaw
« on: 18 February, 2022, 09:26:45 PM »
Hello,
I just received my refurbished wiring loom from Jays Auto Cablage.
Swift and professional!
I do however have some questions regarding the routing of the harness, especially the rear harness.
1. The rear harness has not been routed through the fuse box backing plate,as most of the other cables has. Is this incorrect? See photo #1.
2.Should this wiring block (see photo#2) be located inside the cabin or next to the fuse box?
3/4.How should the rear harness be routed from here (see photo#3)? Should it follow the edge of the mat down to the hole in photo#4, or should it be inside the cavity of the speaker hole.
5.Where should the harness exit the sill?
My car has had a lot of bodywork done, so the original exit hole might have been covered over.
Hope you can help me out, thank you!
Best regards
Torstein
* 1_rear harness will be pinched_should it be routed through the backing plate.jpg (709.2 KB, 1512x2016 - viewed 138 times.)
* 2_should this block be located inside the cabin or in the engine bay.jpg (300.22 KB, 907x1210 - viewed 137 times.)
* 4_should the rear harness enter the inner sill here.JPG (386.13 KB, 907x1210 - viewed 149 times.)
* 5_where should the rear harness eit from the inner sill.JPG (304.72 KB, 907x1210 - viewed 152 times.)
Torstein
1955 Aurelia B20
1966 Fulvia
1966 Fulvia rally/race car
impaw
« Reply #1 on: 21 February, 2022, 08:30:58 PM »
…perhaps this hole is for the rear harness?
This is right next to the fuse box.
Torstein
1955 Aurelia B20
1966 Fulvia
impaw
« Reply #2 on: 23 February, 2022, 11:11:51 PM »
Everything sorted except for correct location of connection block, photo #2  Huh? Huh? Huh?
Torstein
1955 Aurelia B20
1966 Fulvia
impaw
« Reply #3 on: 24 February, 2022, 12:59:47 PM »
I have now sorted this
Torstein
1955 Aurelia B20
1966 Fulvia
Page created in 0.736 seconds with 20 queries.
