next step was to remove the m8 nut on the front of the pump , when this is removed the pullys can be removed from the pump body and the impeller drawn out through the rear ( do not lose thrust washer from spindle!)
there is a big circlip that holds the tensioner body to the pump body, remove this and the tensioner body will slide off the pump body .
next you will need to remove the gland nut from the pump body , fortunately my dad had made the spanner to undo this , it was incredibly tight and it is LEFT HAND THREAD !!!! i mounted the pump in the lathe , locked the chuck solid and used the tail stock to put pressure on the tool so that it didn't slip .
once removed there is a female brass washer which is spring loaded behind the nut that has just been removed , remove this with a hook tool, behind that is the pump packing , this can then be removed with a hook tool also .
Thats it stripped , next step rebuild , i pressed out the bronze bush out of the pump body and pressed in one of the new ones, the pump body was then mounted back in the lathe and i reamed out the bush to 12mm .
next job was to fit the new spindle to the impeller, there is a 4mm pin that holds them together that is riveted over, i drilled the new spindle and made a new pin/ rivet and reassembled. when this was done i wrapped 3 turns of 5mm gland packing rope around the spindle , carefully chamfered the ends to a taper so that they fit into the female tapers of the gland , remove from the spindle , grease lightly with waterpump grease then wind / screw it into the pump body .
next i put more grease in the bearing , refitted thrust washer to spindle and fitted the spindle into the pump and through the new seal .refit the gland washer, i settled this with a light "tap" with a hammer and deep socket then re fitted the spring and LH threaded nut and tighten.
there should be some friction from the seal but the spindle should also turn freely at this point .
the new spindle has 10mm flats rather than the original 8mm flats, this is so that the wear in the drive gear can be filed out as the drive wears to an 8 shape rather than a 0 shape , this took 10 mins with a needle file to do.
refit the tensioner body to pump , circlip , lightly oil body and gears and refit , refit nut and washer and make sure there is no endloat but that pump turns freely too , endfloat can be set with washer on the end of the spindle , i needed to make a slightly thicker one than had come off it .
