27 November, 2024, 08:49:12 AM *
Author Topic: Engine Stabilising Arm Setting  (Read 1767 times)
Barry.Cook
« on: 25 May, 2022, 06:18:48 AM »
Hi,
    Could anyone tell me what the gap should be between the subframe and the stabilising arm on the righthand side of the engine? The car is a 1600HF.
Many thanks,
                    Barry
Cars Owned
1972 Fulvia 1600 HF Lusso
1966 Triumph TR4a
« Reply #1 on: 25 May, 2022, 06:31:02 AM »
Make sure the rubber pad is still there. I always set to touching. Also check the welding has not cracked either at the plate or adjuster. If it cannot be adjusted maybe the exhaust side engine mounts are worn.
Barry.Cook
« Reply #2 on: 25 May, 2022, 08:05:18 AM »
Thank you for such a swift response. The rubber is still there and there is sufficient adjustment so I will now set it as you suggest.
Regards,
             Barry
Cars Owned
1966 Triumph TR4a
« Reply #3 on: 31 May, 2022, 06:51:09 AM »
The Lancia manual says 2 mm clearance, Andrea
