23 November, 2024, 02:22:47 PM *
Author Topic: Water pump housing anyone?  (Read 2141 times)
Caracad
« on: 18 August, 2022, 06:44:31 PM »
Spigots on mine are badly corroded.
bobhenry999
« Reply #1 on: 19 August, 2022, 02:38:38 PM »
I got a good used one from Omicron a couple of years ago from my Coupe so it might be worth giving Andrew or Tristan a call.
Bob
Flavia 815 Vignale
Flavia 819 Milleotto
Flavia 815 Coupe Inezione
2000HF x2
2000 Coupe
2000 Sedan x3
BlueKSO
63 Flavia Coupe
« Reply #2 on: 26 August, 2022, 01:28:42 PM »
What model number Flavia. The earlier 815 is different from the 819.
I know the whereabouts of a housing from an 819, because I had the water pump for my 815 !
Cheers,  Peter
« Reply #3 on: 26 August, 2022, 04:36:57 PM »
Cheers,  Peter
Sorry Peter but the 819 housing went to Australia!!!
Running Board
« Reply #4 on: 27 August, 2022, 07:27:01 AM »
I might have one , will have a look over the weekend
Caracad
« Reply #5 on: 29 August, 2022, 07:47:53 AM »
Thanks for the replies everyone.
My car is a Kugelfischer 2000 coupe. Pump is the same as the earlier 1500/1800 Kugelfischer cars.
I have managed to repair my pump housing. Found that 22mm copper pipe fitted nice and tightly into one spigot. I used epoxy adhesive to fix and seal it. The other spigot was okay with a clean up and repair with same adhesive.
I then found that the thermostat housing was even worse.
Have also made a temporary repair so that I can use the car while the weather is good.
Longer term I want to replace both housings when I can find replacements.
Page created in 0.076 seconds with 20 queries.
