Author Topic: Artena Dynamo/ regulator  (Read 2743 times)
a1city
  • Member
« on: 17 October, 2022, 06:35:40 PM »
Can anyone recommend a good company to rebuild my Dynamo and regulator . 1934 artena
donw
  • Megaposter
Re: Artena Dynamo/ regulator
« Reply #1 on: 18 October, 2022, 03:34:56 PM »
If you cant get it rebuilt, you can use a VW one mine has one if you need it I'll look & see if I can see a number on it.
Don
Don Williamson
1917 Theta 2str
1926 Lambda torpedo
1930 Artena berlina
1933 Belna coupe
williamcorke
  • Rebel Poster
  • B10
« Reply #2 on: 18 October, 2022, 07:09:14 PM »
Where are you based? I (and others on this forum) have used a company local to me in Dorking called Morgan with good results. They certainly know their way around 50's Bosch, Lucas & Marelli, and I don't suppose the 30's item would be much different in design (my 'Aprilia's 37 Marelli / Bosch dynamo certainly isn't).
http://www.jmorganandson.co.uk/
'37 Aprilia
'50 B10
'53 B20
'68 Flavia Vignale
'55 Giulietta Sprint
S1 Land Rover
a1city
  • Member
« Reply #3 on: 18 October, 2022, 08:06:31 PM »
Many thanks for the info, I’ll contact Morgan and don I would appreciate the number off the one you used.
             Cheers dave
CesareFerrari
  • Member
« Reply #4 on: 18 October, 2022, 09:16:48 PM »
This firm rebuilt the dynamo and regulator on my Aprilia a few years ago with excellent results. The principal is called Peter, if I remember correctly, and he has also done good work on at least one Lambda, I believe- https://www.dynamoregulatorconversions.com
