andyp911
« Reply #105 on: 05 April, 2023, 07:03:38 AM » |
the rear with both tubes in.
andyp911
« Reply #106 on: 05 April, 2023, 07:05:27 AM » |
just to tie it together, made the cross brace. there's more to attach to this.
andyp911
« Reply #107 on: 05 April, 2023, 07:06:10 AM » |
another angle.
JollyClubUK
« Reply #108 on: 05 April, 2023, 08:05:47 AM » |
This is just superb the attention to detail with the cage is amazing. How many hours into the project so far? Look forward to seeing the updates as they come.
andyp911
« Reply #109 on: 05 April, 2023, 02:35:03 PM » |
From the start of the project I would estimate about 200 hours. I have been working on it between other work, so an exact figure is difficult.
JollyClubUK
« Reply #110 on: 05 April, 2023, 03:10:12 PM » |
Your own car or a customers? Restoration hours soon add up.
Kevinlincs
« Reply #111 on: 05 April, 2023, 09:04:33 PM » |
There's so much in this to create a 3D masterpiece from fresh air, unbelievable. Do you do it all from self calculated drawings? To calculate positions of suspension pick up points, gearbox mounts etc all from points in fresh air, well it's very impressive. The circular stiffenner indents, do you do them with a fly press? Only I'm sure I've seen hand held tools before, or maybe that was a circular large hole cutter Fantastic stuff
Flavia 815 coupe Dedra turbo Delta integrale
andyp911
« Reply #112 on: 06 April, 2023, 05:42:36 AM » |
its my own car, hence no exact figure on the hours. Thanks Kevin. yes, most of it has just been worked out bit by bit. The indents I just knocked up a pattern, and did them on the workshop press.
andyp911
« Reply #113 on: 11 April, 2023, 03:17:49 PM » |
had a good easter cracking on with brackets, mounts etc.
andyp911
« Reply #114 on: 11 April, 2023, 03:19:13 PM » |
another view.
andyp911
« Reply #115 on: 11 April, 2023, 03:22:24 PM » |
ive welded in reinforcing gussets. I don't know if they're are standard, but a company that prepares the shells, Italian I think, they put them in. makes sense to do the same.
andyp911
« Reply #116 on: 13 April, 2023, 07:24:23 AM » |
rear cradle in position.
andyp911
« Reply #117 on: 13 April, 2023, 07:25:06 AM » |
another angle.
JollyClubUK
« Reply #118 on: 13 April, 2023, 01:21:22 PM » |
Simply stunning fabrication bellissamo!
Mihran
« Reply #119 on: 13 April, 2023, 01:58:10 PM » |
Remarkable work... well done!
Fulvia s1, Thema 8.32 and a Citroen 2cv for diversity :-)
