24 November, 2024, 04:40:25 AM *
Pages: 1 ... 5 6 7 8 9 [10] 11   Go Down
Author Topic: Project 037  (Read 31667 times)
andyp911
« Reply #135 on: 20 November, 2023, 06:15:35 PM »
A few photos of recent work. Front and rear wishbones are nearing completion. Interior work is taking shape, trying to get as much work finished on the shell so I can strip it and get it primed. Will probably order the wheels this week. Once they are here, approx 8 weeks, I can weld the brackets on for the rear dampers.I want to keep everything as tight as possible. I can also finish off the rear brackets for the side panels and start work on the fuel tanks, which Ill make out of 304 stainless, and the exhaust manifold and system. Again, Ill make them out of 304 stainless.
andyp911
« Reply #136 on: 20 November, 2023, 06:16:33 PM »
suspension.
andyp911
« Reply #137 on: 20 November, 2023, 06:17:16 PM »
rear end.
andyp911
« Reply #138 on: 20 November, 2023, 06:18:29 PM »
some interior work.
andyp911
« Reply #139 on: 20 November, 2023, 06:19:22 PM »
Dashboard mocked up.
andyp911
« Reply #140 on: 20 November, 2023, 06:22:02 PM »
Pedal box installed. As Ive used a Porsche 911 steering rack and bias brake assembly, Ive made a new steering column to give more clearance for the steering linkage. This might mean a few mods to the battery tray, but it will be a lot safer.
Kevinlincs
« Reply #141 on: 20 November, 2023, 09:39:57 PM »
A work of art, purely and simply a work of art  Cool
Flavia 815 coupe
Delta integrale
« Reply #142 on: 21 November, 2023, 06:27:34 PM »
That's brightened my day!   Beautiful.
Interesting to see how long the wishbones are, more a surprise at the front than the back, and the choice of heights for the top wishbone inboard mounts.
andyp911
« Reply #143 on: 24 November, 2023, 08:01:25 AM »
David, the wishbone positioning, certainly on the front, is to eliminate bump steer. because I've used Alfa 4c front uprights, and a Porsche 911 rack, there was a bit of buggering about to do (technical term) to get the angles right.
andyp911
« Reply #144 on: 27 November, 2023, 04:51:41 PM »
had a few hours spare over the weekend, so decided to mock up the rear frame that supports the clam. Ive rose jointed the struts, so I have adjustment when I get round to fitting and altering the bodywork.
andyp911
« Reply #145 on: 27 November, 2023, 04:53:05 PM »
another view. Still have to finally weld, its all just tacked for now.
andyp911
« Reply #146 on: 27 November, 2023, 04:54:56 PM »
rear view, you can just see the rose joints in this one. Ive made a start on the front clam mounts, Ill post pictures when Im somewhere near.
andyp911
« Reply #147 on: 13 December, 2023, 10:51:30 PM »
started work on the fuel tanks. decided to make them in 304 stainless, 16g. this is the right hand tank, the left is a mirror. ill weld the top on when the fittings arrive,
AN-6 for the fuel lines, and the bosses for the VDO dip tubes. leak tested well, and capacity is 38 litres per tank.
« Last Edit: 22 December, 2023, 06:34:07 PM by peteracs » Logged
andyp911
« Reply #148 on: 13 December, 2023, 10:53:04 PM »
another angle;
« Last Edit: 22 December, 2023, 06:34:24 PM by peteracs » Logged
andyp911
« Reply #149 on: 13 December, 2023, 10:54:50 PM »
sorry about the photos being the wrong way round. I'm not sure how to alter them.
(Now modified, Peter/Admin)
« Last Edit: 22 December, 2023, 06:35:14 PM by peteracs » Logged
Pages: 1 ... 5 6 7 8 9 [10] 11   Go Up
