Hi Ian,
Glad the power steering pump is now purring.
Windscreen wash warning light, gently prise the sender out of the washer tank and clean up, as I recall it's it has a float around the central core which tends to get gunged up with the screen additive residue, & while you're at it clean the terminals, with a bit of luck that should fix it.
Rear Wheel Bearings only available from Fiat/Lancia as the complete Hub & Bearing although both sides use the same hub, however if you do go this route check first if you have ABS, if so you require 46425959 (£132.49 list 2005). or non ABS 51754192 (£50.45 List 2005).
however if you go onto ebay europe enter item 230279677965 then go to the sellers shop, once in there in the search put Lancia, you will find that they will supply Hub Asms with or without phonic rings, single bearing kits, or a kit with 2 of everything you need at very reasonable prices.
Idle Control Valve, the clean out you did doesn't seem to have lasted long! I usually leave it upside down to soak overnight, filled with WD40, Plus Gas or your favourite cleaner, a good work out of the centre valve against it's (strong) spring, then another flush out usually works, if this doesn't work then I think you're in the market for a replacement; I have read elsewhere, but I can't remember where, that you can take it completely apart to clean, as this involves a strong spring & visions of it shooting off behind the workbench somewhere never to be found, & making sure everything lines back up the way it was, I'd sooner not
Dedra's always look best on OEM Wheels, although you can go to 195x15 tyres & 15" wheels as fitted to Dedra Turbo, I was always unhappy at the coarse ride these gave, compared to the excellent ride on standard 14" Dedra Alloys.
Sounds like you need a set of Dutch Number plates
8227
