21 December, 2024, 03:47:21 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
Model Technical and Interest
Fulvia
Position for front axle stands
Pages: [
1
Go Down
« previous
next »
Author
Topic: Position for front axle stands (Read 1585 times)
HBG
on:
29 April, 2023, 05:58:44 PM »
Hi folks. The weather looks good tomorrow and I want to put the car on axle stands and get it undersealed and waxed.
I can see the rear central jacking point and will put stands under the beam axle. What to do at the front? I can also see the cross member under the engine which has signs of previous jacking and the very front member which is mentioned in the manual as good for jacking, but where to put the front axle stands without doing damage?
Also any tips for cavity waxing/ sealing gratefully received.
Thanks for your help.
Howard
Last Edit: 29 April, 2023, 10:23:16 PM by HBG
Re: Position for front axle stands
Reply #1 on:
30 April, 2023, 07:52:01 AM »
Usually I put an axle stand under each rear spring mounting point. At the front you can use stands under the antiroll bar mounts, the rear subframe mounts under the B pillar if you know these have been repaired, or under the front or rear lower wishbone mounting. Crossmembers were not designed for jacking. Unless you know the car has had new inner and out cills replaced do not use the jacking points...
1998 Zeta 21. 12v
HBG
Reply #2 on:
30 April, 2023, 08:05:17 AM »
Thanks Tim. I'll certainly be careful. The sills and a posts look good, but I'll not take the chance.
Howard
HBG
Reply #3 on:
30 April, 2023, 09:01:24 PM »
All done. Just need to do the doors and behind the rear side panels. Also the handbrake crossmember. Will finish it tomorrow.
Managed to get covered in the stuff but kept it off the drive paving.
Last Edit: 01 May, 2023, 01:58:43 PM by HBG
HBG
Reply #4 on:
01 May, 2023, 03:02:22 PM »
All done now. I used aerosols and went through:
5 x 3M Schutz for the wheel arches.
5 x Dinitrol 4941 for the main under body areas.
4 x Dinitrol ML for priming before the 4941, sills, box sections etc
4 x Dinitrol 1000 clear for engine bay painted areas, bonnet/ boot lids and doors/ behind rear side panels.
Would have used ML for doors had I not run out.
Regarding jacking points, I have an original blue scissor jack. I probably would use it if required at the road side but what do others use if the structural rigidity isn't there?1
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
